is it normal to find oil leaking out of the oil filler cap?
Yes, if you just turned your engine off, oil needs to lubircate some parts under your valve cover. But not too much oil. Or your oil filler cap was not fully shut close prior to checking.
dapat walang leak sa oil filler cap. try mo alisin yung cap tapos i rev mo yung engine. kung may langis na lumalabas, pa check mo na sa mekaniko.
