Results 1 to 10 of 20
November 20th, 2004 04:14 AM #1
what could be the problem pag may ugong yung car pagdating ng 60kph? kanina ko lang kasi napansin while going for a long drive. basta pagdating nya ng 60kph ay may kakaibang ugong kang madidinig. you can feel it kahit sa accelerator pedal. para bang tunog pag nag-engine brake pero consistent. pag below 60kph ay nawawala naman yung ugong. although smoooth naman yung andar ng engine at wala naman vibration sa body. naitakbo ko siya kanina for 200kms. at 1st, kala ko yung gulong but pinakinggan ko mabuti at hindi naman yun..
sorry but ang alam ko lang kasi ay mag-drive at no knowledge ako pagdating sa troubleshooting. so please, i need your advice...
it's a '01 Revo 2.0L Gas A/T
mileage - 64,000 + (last PMS was at 50k)
tires- bridgestone (about 6 months old)
could it be the tranny???
November 20th, 2004 04:56 AM #2
baka wheel bearing, try to search the forums regarding wheel bearing.
November 20th, 2004 07:54 AM #3
6 months wheel bearing agad?
pwede ring gulong..dati yung goodyear gps2 ko ganyan din..pagdating ng 60 ang ugong.
November 20th, 2004 09:51 AM #4
sa amin pag umuugong na at 60km/h or more..almost always wheel bearing.
- Aug 2003
- 9,720
November 20th, 2004 11:44 AM #7
Nangyari na sa akin yan a long time ago. At first I really thought it was the wheel bearing. Pag check ko okay naman sya, since naka tanggal na i had it repacked. Pag gamit ko ng car nandun pa rin yung noise. Then pina check ko balancing ng wheels. Ayun! Natanggal yung ugong.
Baka din nagsisimula magkabukol yung tire mo. Nalubak ka ba? Try mo rin muna pa check balancing. Mura lang yun, mga 30-40 pesos lang yata per tire. Front tires lang naman kailangan mo pa check.
November 20th, 2004 11:58 AM #8
Try to have your tires balanced. Pag Goatyear este Goodyear yan, have it checked for 'bukol'.
Tsikot Member Rank 3
- Oct 2003
- 734
November 20th, 2004 01:29 PM #9akala ko ako lang may problem sa ugong may iba rin pala dito same here pag 60 kph pataas umuugong somewhere sa ilalim at yun tunog nya ay sumasabay sa bilis at apak ko lumalakas pag mabilis. it is like a deep throaty, low freq, resonating sound coming from underneath and it is irritating hindi kaya sa muffler yun?
November 20th, 2004 03:04 PM #10
the tires are Bridgestone, got it balanced and aligned nung pinalitan ko 6 months ago.
yes, nababad siya sa baha overnight when i got stranded pero it was 2 months ago na. and parati ko siya ginagamit for long drives at least once a week pero ngayon lang siya nagka-ugong.
talaga bang ganun pag bearing ang sira, may certain speed lang na mag-uumpisa umugong? pag kasi lumampas ng 90kph ay humihina yung ugong? or guni-guni ko lang yun...hehehe :confused:
san ba pwede patingnan yung bearing? kailangan na ba palitan yun? nabasa ko sa iba na nire-repack daw yun? how is this done and where?
about the tires, i'll have it balanced again.
