Results 11 to 16 of 16
January 3rd, 2008 03:46 PM #11
TheOneThatIs
- 1,306
January 3rd, 2008 04:41 PM #12I just got back from Banawe. I got three (3) sets of timing belts (original Toyota, I got it for 1,490 Php), tensioners and idlers. Thanks a lot guys. Buti na lang hindi ko pa nakabit yung Gates.
Another question: I also have two (2) Nissan Sentra GX taxis (yung new body, 2004 and 2006 model). How different is this in terms of maintenance versus the Lovelife Corollas?
TIA.
January 3rd, 2008 04:48 PM #13
Stick to regular 20W-40 mineral oil and change it every 5,000kms (Petron oils are one of the more lower priced ones); no need for additives of flushes. Spark plugs are changed every 10,000kms but if you want a little more longevity then use platinum spark plugs. Fuel filter also has to be changed every 20,000kms along with the air filter (w/c is cleaned every 5,000kms).
The original T-belts cost more than 1K; if you have to change bearings, just get the Koyo brand, they're the same as the originals w/c Toyota uses.
Check also the cooling system (flush and clean every 40,000kms usually), a/c and alternator belts, and do the public a favor by keeping the Taxis clean inside and out; it goes a long way for both the owner and the passenger. ;)
IMO, it helps a lot if the driver's see you personally checking the units once in a while.
January 3rd, 2008 05:12 PM #14
imho... the nissans are in timing chains, so no need to replace them at that kilometer reading. but have them checked at around 80k kms for the tension.
for the maintenance, aside from the usual fluid changes, you may also want to check the condition of the fan belts, the aircon (heck, who wants to ride in a hot taxi), the suspension (nissans have more softer suspensions than toyotas, so mas marupok sya).
January 4th, 2008 09:53 AM #15
pre ingat ka lang sa timing belt na binibili mo dami kasi ngayon timing belt na original yun packing pareho sila pag compare mo sa original.
TheOneThatIs
- 1,306
January 4th, 2008 10:23 AM #16
I would lean more towards technological solutions instead of deputized traffic wardens, whenever...
SC (temporarily) stops NCAP
