Results 1 to 9 of 9
- Aug 2003
- 317
January 8th, 2004 11:09 PM #1yung civic ng sister ko tumataas ang temp kapag gabi lang. quite the opposite of what usually happens. this is because nakabukas ang ilaw. pero pag pinatay ang ilaw bababa nanaman siya ulit. electrical problem kaya? umaandar naman yung aux fan. although nung minsan mataas na di pa rin umaandar. tapos nung umandar sandali lang patay na ulet kahit hindi pa bumaba yung temp.
help! ano kaya problema?
January 9th, 2004 01:08 AM #2
ek2jayvee:::whew...handles are getting harder to type with every new member, anyways looks like you have a day car to me. Seriously, your lights might be robbing your aux fan of current everytime you turn it on. Try it during day time and see if the temp rises. If yes, then you have to check the groundings of your aux fan. It migh be rotating, but is it rotating with the right RPM?
January 9th, 2004 02:47 AM #3
yes likely kulang ng current ang fan mo. sa akin nangyari ito. akala ko battery, alternator... higpit lang ng screw sa ground ok na.
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 9th, 2004 02:01 PM #4happened narin to my car. the problem is probably in your body grounds have them changed and you'll be good as new!
- Aug 2003
- 317
January 10th, 2004 02:11 AM #5ok thanks. i'll have it checked. i tried turning on the lights during daytime and tumataas pa rin.
- Aug 2003
- 317
January 10th, 2004 02:15 AM #6by the way sir afrasay, pwede na ang jayvee so it wouldn't be to difficult. hehe
- Nov 2002
- 51
January 10th, 2004 09:23 PM #7I'm sure butas ang radiator mo kaya nagooverheat. Pour a bottle of Whiz Radiator Stop Leak at solve yang problem mo.
January 11th, 2004 10:36 PM #8
Kung sumasabay sa ilaw, malamang nga electrical iyan. Kasi tumaas ang temp when you drove with the lights on during daytime diba.
January 11th, 2004 11:33 PM #9
nangyari sakin yan...water pump pala sira....di makasabay.
pero hmm...mukhang may possibility na electrical ah....
MMPC achieves highest annual sales volume with 81,743 vehicles sold | Autoindustriya
Car Sales Data (2023)
