Results 1 to 10 of 24
March 25th, 2007 07:36 PM #1
our driver lost the car key probably near the vicinity of our place in manila, avenida area.
the remote could be reset however how about using the car key manually? would there be any way that the keys could be change as well without changing the locks?
March 25th, 2007 08:22 PM #2
You won't have to change the locks. A dealership should be able to cut a new key if you show up with the ownership and/or proof that you are in fact the proper owner of the vehicle.
March 25th, 2007 08:24 PM #3
change both.. you wouldn't know what may happen to your car.. bka mamya modus ope-ekek ng driver m yan??
March 25th, 2007 08:55 PM #4
di ako araw araw asa manila, pero pano nga kung na modus operandi ako, tipong ngayon ok sasakyan ko pero next week matiktikan at pwede nang mabuksan ng nakakuha ng susi...
pwede bang palitan yung key slot and key ng toyota? i asked to reset and have another key would cost 14,000, would that mean the old key would not fit anymore, even if used manually?
March 25th, 2007 09:04 PM #5
di ko pa na eexperience mkpg change ng car key system or even a reset..
pero kung reset, di na pwede yung nawala mong key for a keyless entry, but for a manual unlock makaka butt in pa rin yung key, pero syempre mag aalarm pa rin yung oto. kc di naman napalitan yung key slot.. am not sure ah..pero sa tingin ko ganun..
at sa tingin ko rin si siR Otep ang makakasagot nyan ng mas claro at sigurado//
BANNED BANNED BANNED
- 3,790
March 25th, 2007 09:19 PM #6kung fortuner yan...yari ka...special key with the transponder.
kung innova or the regular toyota's....try changing the entrance key na lang...like the solex keys of the old days.
then ask your suking alarm shop to install a hidden switch to disengage the car (usually starter)...kaso baka pati driver mo kasabwat...
sa US uso na yung parang transponder type na alarm...merun itong "key chain" that carries a sensor/transmitter that the alarm unit senses na malapit lang para the car will engage otherwise it won't start the car....same principle ng transponder keys ng fortuners.
March 25th, 2007 09:55 PM #7
mahal key ng Fortuner, driver namin na misplace last time yun key, I ask toyota, price around 13,000/pc, buti na lang nahanap din after 3 weeks
March 25th, 2007 11:07 PM #8
March 25th, 2007 11:33 PM #9
The problem of cutedoc is the lost key can be used to open his car. Is there a way to prevent this without having to change the door locks and the ignition switch?
March 25th, 2007 11:49 PM #10
ayoko magdagdag ng solex yung old school door lock parang ang baduy hehehe
14,000 each yung susi... mahal nga, before i tried to have the key duplicated ayaw mabuksan rav4 ko, pero yung mga duplicated key ng revo ang hi ace pwede...
ill ask toyota tom what they could do with this
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
