What is the "Alegre EXHAUST GAS OXIDIZER" or 'EGO'?
It is a post-combustion system with the 'EGO' device weld-installed at the tip of the exhaust tail pipe, far away from direct engine's performance, yet it is an integral part to engine's efficiency. It works on the principle of "dual-venturi" system where the present exhaust flow is enhanced to increase its velocity with rapid and turbulent flow, effecting a scavenging condition within the entire system or "siphoning effect" from the 'EGO' device that efficiently disperses-out all the unburnt gases and left-over wastes including carbon deposits inside the combustion chambers. Hence, the subsequent intake of air-fuel is therefore assured to be in the homogeneous state, ensuring an ideal mixture for a "near-perfect combustion".
This brilliant innovation to the conventional exhaust piping system introduced by the breakthrough 'EGO' device results to:
