Results 1 to 5 of 5
June 10th, 2006 11:02 PM #1
Peeps which is more effective and best for a turbocharged diesel or gasoline vehicle, a water-to-air intercooler or an air-to-air intercooler?Thanks!
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 11th, 2006 02:50 PM #2air to water is better for short spurts but unless you have a separate heat exchanger which cools down the water you'll feel it get sluggish after a while. air to air na front mount is best for 90% of situations.
June 11th, 2006 11:07 PM #3
air/water intercooler are usually used if there are some space/packaging limitations.
- Nov 2003
- 3,848
June 12th, 2006 10:54 PM #5normally pang drag since it's more effective especially if you put ice or something like that sa ic. air/water sometimes takes up more space pa than the plumbing of the fmic's since people like placing it near the throttle body, which cramps up the engine bay.
A little ot: I disputed several charges credited to me a month ago and mptc finally corrected ...
cavitex easydrive error
