Results 1 to 1 of 1
- Jul 2006
- 28
November 1st, 2006 01:05 PM #1mga sirs patulong naman po ung sasakyan ko namamatay makina mag isa recently lang ngyari to , namamatay makina po twing ung sasakyan nagstart after mga 10 to 15 mins after cold start pero pag i crank ko ulet from acc position ayaw mag start kahet kadyot pero pagbnalik ko sa off tpos ung susian magstart cya nacheck ko na po lahat ful pump wiring tension wire fuel filter, malinis naman po wala bara fuel line halos lahat na pero wala pa rin dko ma gets tlaga, kasi po pagnamamatay parang pnatay mula susian parang nawalan ng kuryente, duda ko distributor pero nagsastart pa din, puro wild guess nlang ako, patulong po... :
btw bago overhaul po naka 710 kms palang since overhaul, bago piston standard pa din po timing belt etc.... gaskets... dko po tlaga ma trace pati mekaniko po namin d maintindihan san galing ung cut off , thanks in advance mag sirs
Hi reviving this thread. Ask lang mga sir if okay ba yung fiamm triple trumpet na horn? May...
What is your car's horn?
