Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    May 2005
    mga sir's, i heard na pinaka ok daw na coolant ay yung Toyota Red Coolant, ok lang ba yun gamitin sa Honda Civic (1994)? if not, may mga masusuggest ba kayo na magandang coolant for this car? thanks!
    read mo manual and check ang toyota coolant kung pereho lang. pwede yon. color i guess ibaiba lang depende sa manufacturer.
    Kung pareho lang ang ingredients ng both coolants, I think wala namang problema yun.
    Dec 2003
    caltex extended life coolant nalang, red
    Jun 2003
    parehas lang lahat yan basta coolant!
    Quote Originally Posted by Sheep
    honga. pare-pareho namang coolant yan.
    Oct 2003
    ako i use petron coolant. ok naman. will be changing to another brand next time, caltex naman..hehe
    Feb 2005
    Yung Toyota coolant and oil is made by Caltex. Dapat Shell kaya lang ayaw mag repack ng shell kaya napunta sa Caltex. Ayun tinanggal din ng Toyota Shell as their fuel sa plant. Ako I use shell glycol kasi gusto ko yung kulay blue na coolant. Prestone kadiri.
    May 2005
    hmmm.. cge, il try caltex' coolant.. thanks po!
  10. #10
    zeagle: ano coolant pwede sa X-trail?
    Feb 2005
    Quote Originally Posted by ILuvDetailing
    A e teka. Di ko pa napagaralan yan ILD. Cge research ko.
    Mar 2005
    Not all coolants are the same!
    If your honda uses extended-life (5 year) coolant you can probably use the new toyota pink coolant.
    If the honda uses conventional (2 year) coolant then you can probaly use the toyota red coolant.
    AFAIK the toyota and honda coolants are quite similar in formula
    Apr 2004
    sa 1996 mazda 323 glxi familia? kasi tubig lang ata nilalagay ko eh
    May 2005
    nyek ndi ko tlga alam kung ano nilalagay sa kotse ko e, honda civic 1994 lx.. pero kahapon, nglagay na ko ng caltex extended life coolant nila.. eon lang.. la naman ako nkitang difference,,, meron ba dapat?!
    nyek din....me ome din ba na coolant or me specific coolant din ba for a certain brand of car??
    kami kahit anong coolant din....pagminsan nga eh yung kulay na lang ang napapagtripan eh...herehrehrher
    but mostly caltex at shell din lang yung for 2yrs para ma-tsek or malinis tuloy yung radiator once in a while.....unless napagawi sa mga car accessories stores dun lang nakakatikim ng special na coolant yung rides namin.....
    extended life yung gamit ng Honda. basta yung lo silicate formula compatible yun sa Honda. Yung prestone i think may silicates pa rin yun.
    Silicates are harmful to Honda waterpump seals
    Quote Originally Posted by Supierreman
    Naku ! ganon pala yon? kala ko eh pare-pareho lang mga coolant's nasa magkano po kaya yung 1 gallon ng honda long-life coolant?
    Mar 2005
    The prestone long-life (not super long life) label says "low silicate" which indicates that it contains silicates, which are abrasive.
    Japanese automakers specify NO SILICATE coolant. There's probably a good reason why.
    wrcastro_ph,
    masyado mahal yung coolant ng honda. 250/L yung premixed na. Yung concentrate nila dati nasa 700+ isang bottle.
    I think yung caltex long life silicate free formula na yun. check out the texaco website. Yun gamit ko sa cr-v ngayon so far ok naman
    http://www.caltexoils.com/Caltex+Int...fe+Coolant.htm
    Premium performance, environmentally sensitive coolant, anti-freeze and corrosion inhibitor, based on extended-life organic acid Carboxylate Technology in ethylene glycol which, when mixed at 50% by volume with water, provides long-term protection of the cooling systems of gasoline and light and heavy-duty diesel engines. Meets the phosphate-free requirements of European manufacturers and the silicate-free requirements of Japanese manufacturers.
    :D
    May 2005
    yung sa caltex, 1L Concentrated: Php 310.. kahapon lang ako bumili e.. haay,, buti naman at tama yung decision ko..
Toyota Coolant on a Honda Car?
