Results 1 to 5 of 5
August 23rd, 2005 07:37 PM #1
Went to the casa last week for 80Km PMS, had my shifter checked as well...
I dont think replacing the cable is the right diagnosis by my SA, knowing na CASA yun, I do expect them to tell me that.
My AT kasi has this problem of not lining up the shifter correctly sa N at D.
Assuming you're looking at the shifter console directly overhead looking down to where PRND21 is printed, these things happen.
Meaning, if you move the shifter downwards (from P to 1 direction) Once you pass R and enter N, the car will be in neutral but the reverse light stays on.
You move the lever somewhere between N and D, it goes off but stays in neutral.
If you move the shifter from N to D, the car stays at neutral, you have to move the shifter somewhere between D and 2 for it to shift to drive.
If you shift from 2 to D or any upward movement, walang problema.
I had it checked and sabi daw yung control cable daw ang problema. Makes sense coz the shifting of the tranny is fine, di lang talaga nagliline up yung shifter.
I don't think a replacement is in order since di naman putol or whatever.
After some searching sa web, most AT has this innards sa may shifter.
As you can see, there are 2 cables displayed and the lower gearshift cable is adjustable.
Tingin ko kayang i-adjust lang eh. Parang kulang lang paghatak nya if you're pulling it downwards.
Any shop you recommend for this job? Looks like a simple (for experts with AT) dismantling of the center console and adjustment. Although I'm sure may technique and procedure sya na specific....
Any help would be appreciated
Thanks a lot.
August 24th, 2005 12:12 AM #2
DIY job iyan sa U.S. Prone din sa ganyan mga Montero. Pero kahit ako medyo mag-aalinlangan with a job like that. Hehehe.
September 9th, 2005 04:28 PM #4
i think its the bushing at the end of the cables....
kung cable ang sira, dapat stiff ang pag select ng gears...
September 19th, 2005 11:42 AM #5
Just an update so other guys may know.
A friend of mine who's a mechanic (banaweonline) took apart my center console and other related interior trim to check the shifter issue.
Turns out that there's a bar sticking out sideways perpendicular from the base of the shift lever.
That bar connects to a metal o-ring ended rod that connects to the clutch control cable.
Simply put, the bushing that's supposed to keep the metal o-ring moving back and forth from the shifter base rod.
Kinda like a grommet. That's it.
All fixed in 30mins or so.
The dealer wanted to replace the whole control cable which has no relations with the said problem... 7K+ singil.
Xiaomi E-Car
