Results 1 to 5 of 5
September 2nd, 2003 09:15 PM #1
i've posted this problem before, but i have new info. i suffer from hesitation (which is what i think you guys call "tope") between 2000 and 3500 rpm.
basically, once the engine reaches that speed (and i have to be moving) it hesitates / coughs / whatever. if the speed exceeds 3500rpm, nawawala ulit :confused:
also the problem doesn't appear at neutral, even when revving the engine.
i have cleaned the MAF, and i have new spark plugs.
the new info i have is, when one of the ignition wires is removed while the engine is running (any one) at idle, the EXACT same sound i get at 2000-3500rpm appears.. hmm...
- Jul 2003
- 44
September 2nd, 2003 10:03 PM #2Then its misfire. Have the hi-tension wires checked. Better have the timing checked too while you're at it.
September 3rd, 2003 07:09 PM #4
baka nga sa HT wires, baka may small cracks na yan.
Test mo HT wires mo in a very dark place (your garage with all the lights off) then rev the engine. observe the HT wires kung meron sparks, kapag meron ibig sabihin may cracks na yan.
September 7th, 2003 02:27 PM #5
several things actually, some ECU's alter timing based on coolant temperature as well... So check your coolant ratio as well...
if you have had you're timing belt changed receintly, baka di tama yung pagkakabit ng belt at di naka TDC
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
