Results 1 to 6 of 6
- Dec 2004
- 41
April 16th, 2005 01:45 PM #1kakatapos lang po ma top overhaul iyong XL 92 Corolla ko. Napalitan iyong exhaust/intake valves, valve guides, piston ring, timing belt, tensioner bearing/balancer. Break-in process po siya ngayon (for 4 months then I am required to bring it back where I had it overhauled).
Ang question ko po, what are the things to observe and monitor that indicate there is a problem sa pagka-overhaul?
thanks for the replies. have a good day.
Toyota is my choice
- Aug 2005
- 2,063
Tsikot Member Rank 3
- Dec 2003
- 546
September 25th, 2005 10:30 PM #3pag bagong overhaul, wag mo i birit, dahan dahan lang
mga kailangan monitor.
1. Leaks, number one eto, minsam mekaniko hindi gumagamit ng torque wrench, basta makabit turnilyo ok na maski wala sa spec
2. Engine oil level
3. Raditor level, baka warped na ang cylinder head mo at tagag ng tagas tubig
4. Temp guage, pag mali ang overhaul, at na block ang oil water jackets patay tayo dyan
5. Knocking sounds. mali paka overhaul o may na iwan na turnilyo or may turnilyo nalaglag sa timing belt area
6. Missing bolts. nyahahah dami ganyan, di na binabalik ang turnilyo
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Nov 2003
- 3,849
October 23rd, 2005 10:35 AM #6depends on the car and what is busted. no way to estimate it without more info on your part.
Xiaomi E-Car
