Results 1 to 4 of 4
- Nov 2006
- 20
November 19th, 2007 03:12 AM #1I'm not really familiar with using this thread/forum so i would appreciate it if you can email me your suggestions/answers at mmanotok*yahoo.com or if you have a sun cell number please text me at 0922-8899008.
Here are my problems.
1. I have a 7 series BMW 94 model. I haven't been using it and the battery died already. Hindi ko na po mabuksan yung pinto ko maski susi-an ko ay ayaw bumukas. Wala naman syang alarm. Meron ba kayong alam na makakapag bukas ng pinto ko? Hindi ko mabuksan yung hood to replace the battery if hindi ko mabuksan yung hood eh.
2. Yung 7 series ko Napakalabo or mahina rin ng headlight ko. Yung bright ay walang problem pero yung dim halos wala akong makita. Can someone help me? ano ba ang dapat kung gawin? Saan ko pwede dalhin? papa-ayos ko when I get to open my door.
Yung Expediton 2000 model ko naman
1. glove compartment bigla na lang bumubukas. parang ayaw na mag lock. may alam ba kayong gumagawa nito? Ayaw ko sana sa casa kasi namumulubi na ako sa casa.
2. Pati yung parang glove compartment sa ceiling ay ayaw na rin mag lock. biglang bumubukas and very irritating.
3. May ingay at kalampag na sa pang ilalim. Normal lang kasi luma na, gusto ko lang sana makatipid sa parts at ayaw ko maloko. can you recommend where I can buy reasonable replacement parts and maybe a shop na hindi taga at manloloko?
Maraming Maraming salamat po in advance. Here is my SUN Cell Number in-case may SUN din kayo 0922-8899008. Again maraming salamat in advance sa tsikot.com and sa helpful members ninyo.
November 19th, 2007 08:22 AM #2
Originally Posted by Street Smart
Baka naman hindi mo pinipihit nang husto? Normally when you turn the key in one direction, the doors will lock. Turn it past this point and it will double-lock. Turn it a bit more and it will synchronize the central locking system ... hold it there until you hear all actuators (including the trunk) engage. That is, if you have a working battery.
When you turn the key in the other direction, it should unlock. Turn it past this point and and you will engage the emergency unlock. This emergency unlock is for times of total electrical failure - like what happened to your car.
In either direction (from the 12 o'clock position to the sync or emergency unlock position) your key should have turned more than 90 degrees.
Due to its age, you may want to have your wirings checked, including the connectors and relay. If the voltage drop between the battery and the headlight is too much, you may want to consider having an extra relay wired-in and use higher-powered bulbs [SIZE=1](note: more than 55/60w is illegal in some countries)[/SIZE]. It's basically bypassing the old relay and headlight wiring with new and thicker wiring (without taking out the old ones, which I'm sure will be too troublesome).
Or use better bulbs like Philips Vision Plus (+50%) or Osram Silverstar (+50%). If you can find the new ones, there's the Philips X-Treme Power (+80%) and Osram Nightbreaker (+90%).
Sorry about your Expedition. Maybe somebody else will help you on that. You may want to bring it over to speedyfix, he's a very helpful member here who has a shop. His website and details are here:
http://www.speedyfixph.com/
At may WiFi free zone pa pala siya para malibang ka.Last edited by StraightSix; November 19th, 2007 at 08:24 AM.
November 19th, 2007 10:09 AM #3
+1 po ako para kay SPEEDYFIX
Very helpful and very reliable,you can check po sa lahat ng post ni Sir SPEEDYFIX.
- Nov 2006
- 20
November 19th, 2007 11:54 AM #4Wow!!!! Super galing the info. Thanks! I just brought the expe to the shop. I have a leak in my radiator and a leak in my suspension since air suspension daw ito.
Hay naku. Never ending maintenance ng car. Plastic ang radiator ng expe. parang gusto ko palitan ng bakal para hindi na mag-crack. may gumagawa ba nito? Is this a stupid idea? Should i just stick to the original plastic radiator?
Thanks again. will try to open the door now.
I would lean more towards technological solutions instead of deputized traffic wardens, whenever...
SC (temporarily) stops NCAP
