Results 1 to 10 of 39
- Oct 2012
- 26
October 24th, 2013 05:03 PM #1Hi everyone,
Can you tell me if I need to have my tires checked?
Last night, I had all tires inflated to 32 PSI.
One tire (left front) was only measured 24 PSI before it got inflated. This was significantly lower compared to the 3 tires which measured 29 PSI.
Common sense tells me I need to have it replaced by the spare tire and have it checked.
If yes, where is the best place to get it checked? Any trusted shops you can recommend in Mandaluyong?
October 24th, 2013 05:09 PM #2
- Oct 2012
- 26
October 24th, 2013 05:14 PM #3Thanks for the quick response.
So ung shop na bahala to inspect kung saan may problem ung goma?
October 24th, 2013 05:25 PM #4
yung dati kong car ganyan dati...lagi sumisingaw...
ginawa nung shop e parang may pinahid sa rim (inside) or pandikit yata kasi daw naupod na..tama naman siya kasi nababad yung gulong ng car sa baha.
October 24th, 2013 05:27 PM #5
Yes, lulubog nila yung tire sa tubig to check for leaks. Papakita naman sayo kung saan nanggagaling yung air leak.
Wag ka lang pupunta sa mga alanganin na shop, find a decent looking shop.
October 24th, 2013 05:41 PM #6
October 24th, 2013 11:20 PM #9
Kung di makita butas, ipa over inflate mo para lumabas hangin sa butas.
- Oct 2012
- 26
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
