Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
    Hi everyone,
    Can you tell me if I need to have my tires checked?
    Last night, I had all tires inflated to 32 PSI.
    One tire (left front) was only measured 24 PSI before it got inflated. This was significantly lower compared to the 3 tires which measured 29 PSI.
    Common sense tells me I need to have it replaced by the spare tire and have it checked.
    If yes, where is the best place to get it checked? Any trusted shops you can recommend in Mandaluyong?
    Quote Originally Posted by nincompoop!! View Post
    Hi everyone,
    No need for a trusted shop for that. As long as they have a tire remover machine and cold patch, ok na.
    Thanks for the quick response.
    So ung shop na bahala to inspect kung saan may problem ung goma?
    Apr 2013
    yung dati kong car ganyan dati...lagi sumisingaw...
    ginawa nung shop e parang may pinahid sa rim (inside) or pandikit yata kasi daw naupod na..tama naman siya kasi nababad yung gulong ng car sa baha.
    Yes, lulubog nila yung tire sa tubig to check for leaks. Papakita naman sayo kung saan nanggagaling yung air leak.
    Wag ka lang pupunta sa mga alanganin na shop, find a decent looking shop.
    Aug 2004
    Quote Originally Posted by [archie] View Post
    Preferably those with a proper tire mounting tool not the martilyo style shops.
    May 2012
    minsan yung pito ang may problema.
    Apr 2013
    yes dun ka sa shop na may machine na pang gulong/rim...
    Kung di makita butas, ipa over inflate mo para lumabas hangin sa butas.
    Thanks everyone, very helpful.
Tire Pressure Question
