Results 1 to 9 of 9
    Apr 2005
    Need Help.
    I just replaced my timing belt (due for PM 90,000 Km) at CAMEO in BF paranaque.
    I noticed after that, humina ang hatak, especially when you need to accelerate (to overtake).
    Had the car checked at Honda CASA.. tama naman daw tension at ngipin nung belt.
    What can i do?
    Sep 2004
    after the timing belt..did you have a tune up? did they check timing.
    naka align ba timing marks ng pulleys?
    Apr 2005
    Quote Originally Posted by afrasay
    Thanks Chief,
    "pinabaril" ko lng sa casa ... sabi okay naman daw..
    not so familiar with 'timing marks'.. is this a different test?
    Nov 2003
    if the timing marks on the pulley are not aligned then it will be hard to get the proper timing from the distributor.
    have both checked again.
    Apr 2005
    Quote Originally Posted by speedyfix
    is this why mahina ang hatak pag overtake ka?
    Nov 2003
    could be one of the reasons. have it checked tho para sure ka. dapat pareho yung takbo ng car before and after timing belt replacement.
    Jan 2004
    Quote Originally Posted by scooby91
    Need Help.
    What can i do?
    sir, being a honda owner too. i'd like to suggest that you try to pin point the problem by isolating the culprit.
    here are some point to check:
    -have you filled the same octane rating for your fuel
    -check your engine vitals, such as the air filter, fuel filter, spark plugs, etc.
    -check all those clearances, especially valve clearance.
    also, if you have time to serf the net, try to find a service manual for honda civic ek series (96-99). the copy i got is is pdf format. maybe this would help you.
    Mar 2005
    pacheck mo kung nakadelay or advance ang marking sa pulley
Timing Belt (Honda Civic'97)
