Results 11 to 19 of 19
November 21st, 2007 09:59 AM #11
November 21st, 2007 10:29 AM #12
yup, aside from the injectors naririnig ko ring tumitick din. Siguro dahil sa expansion while heated then baka when its cooling down nagcocompress na uli (my theory tho)
November 21st, 2007 02:59 PM #13
metal part po yan usually sa exhaust or dun sa header.
temperature difference from mainit to lumalamig kaya ganyan
November 22nd, 2007 07:17 AM #14
wow. naririnig ko rin to sa auto ko. kala ko me problema na.
bagong kaalaman na naman.
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 25th, 2007 06:20 PM #15the injectors should not make noise when the engine is not on. when the engine is on then may konting konting ingay lang dapat.
December 4th, 2007 01:38 AM #17
December 4th, 2007 06:09 PM #18
- Nov 2003
- 3,848
December 4th, 2007 08:00 PM #19gas should not cause that sound lalo na when the engine is off. it might cause it when you're running and the engine is knocking...
good. these trucks are taking up too much space they don't fit into normal slots anymore. this...
PH Gov't looking to bring back excise tax for...
