Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Jun 2007
    oh my bad, but I recently inquire about this problem and the mechanic told me that it is just the injectors cooling down, oh well
    Quote Originally Posted by mazingerZ View Post
    Its the metal protector thingy na nakatakip sa exhaust manifold thats ticking. Observed it also when I park after a long drive.
    ano yan? yung nakatakip dun sa headers?
    yup, aside from the injectors naririnig ko ring tumitick din. Siguro dahil sa expansion while heated then baka when its cooling down nagcocompress na uli (my theory tho)
    Jul 2006
    metal part po yan usually sa exhaust or dun sa header.
    temperature difference from mainit to lumalamig kaya ganyan
    Feb 2006
    wow. naririnig ko rin to sa auto ko. kala ko me problema na.
    bagong kaalaman na naman.
    Nov 2003
    the injectors should not make noise when the engine is not on. when the engine is on then may konting konting ingay lang dapat.
    Aug 2007
    wala bang pwedeng gawing solusyon don, nakakairita minsan.
    Aug 2007
    Quote Originally Posted by jansky View Post
    hello to all tsikoteers
    may problem po sasakyan ko pag off ko ng makina may tiktik sound cya sa ilalim ng makina.. pero after a few minute nawawala po cya ano po kaya yun? ano rin cause ng problema nun?
    Nissan
    Maraming salamt
    Sa akin pag tumatakbo lang maririnig yung tik tik parang static ng kuryente
    Jul 2006
    Nissan
    Maraming salamt
    I don't recall where I heard this but if you're using the cheapest gasoline your car will have this kind of sound after turning the engine off. I'm a dieselhead so I'm not too knowledgeable on that but maybe it can lead to something
    Nov 2003
    gas should not cause that sound lalo na when the engine is off. it might cause it when you're running and the engine is knocking...
tik tik sound problem
