Results 1 to 10 of 19
November 19th, 2007 11:49 PM #1
hello to all tsikoteers
may problem po sasakyan ko pag off ko ng makina may tiktik sound cya sa ilalim ng makina.. pero after a few minute nawawala po cya ano po kaya yun? ano rin cause ng problema nun?
Nissan
Maraming salamt
- Aug 2007
- 117
November 20th, 2007 12:54 AM #2ask ko lang, kaka undercoat mu lang ba? naexperience ko itong sound nung kakaundercoat ko lang tuwing nag shutdown nung engine nung CRV ko me sound din na parang tik tik sbi daw naiinitan yung coating near the engine. . .
November 20th, 2007 01:12 AM #3
after turning off? di ba normal lang to? lalo na kung kabubuhay mo palang ng engine inihataw mo na agad! just my observation.
November 20th, 2007 09:58 AM #4
alam ko normal lang din ito. meron din nito sa oto ko eh.
i assume its part of the engine cooling down.
November 20th, 2007 10:02 AM #5
it's normal....unless you have enemies who are drug lords, in which case you should check for time bombs
but seriously, usually that sound comes from the cooling down process of the engine and the joints/parts, as Vlady said.
November 20th, 2007 10:23 AM #6
normal lang po ito. nag-cocool down po kasi ang mga metal parts kaya nag-titiktik.
November 20th, 2007 06:49 PM #7
thanks po sa input nyo kala ko may problema na sasakyan ko
dami ko talga natutunan dito
and again thanks
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 20th, 2007 11:21 PM #9it's not the injectors cooling down. normally it is either the brakes or the metal in the exhaust.
November 21st, 2007 08:56 AM #10
+1 kay sir speedy. .
Its the metal protector thingy na nakatakip sa exhaust manifold thats ticking. Observed it also when I park after a long drive.
For someone having experience working with Japanese team, I am sure they already anticipated this....
BYD Philippines
