Results 1 to 10 of 30
March 8th, 2005 12:26 AM #1
For the Spark Plug It says 19.6 - 29.4 N-m (2.0 - 3.0 kg-m, 15 - 21 lb ft). How many revolutions is this? Thanks in advance.
- Feb 2005
- 34
March 8th, 2005 02:06 AM #4yup, pwede tantsahan.
i work with car manufacturing before. ang standard, we use click torque wrench for all fasteners. kung wala kang gamit (click wrench or dial torque wrench) tantsahin mo na lang. when you feel na kumagat na yung last thread nya (using a wrench ha, not a hand tight), ipihit mo pa ng about 15 degrees. pwede na yun.
March 8th, 2005 12:57 PM #5
pag sparkplugs, ilan degrees after you hand tight it? In caltex MIA they use a machine (don't know what its called) to tighten the sparkplugs so I can't see how many degrees. Thanks.
March 8th, 2005 06:44 PM #6
If you really need to check or replace the sparkplug yourself, I suggest to invest on a good torque wrench. Marami pa namang ibang gamit ito beside the sparkplug replacement. Warning, madaling ma-loose thread ang aluminum cylinder head.
March 8th, 2005 07:28 PM #7
kung geographically near lang tayo, pahiramin kita. but i live in the northmost part of M.M.(and i think south ka).
March 8th, 2005 07:45 PM #8
Suggest ko din torque wrench. O kaya avoid overtorquing na lang. Medyo critical area iyang kabitan ng spark plug. Kapag nagkamali ka diyan, nakupow!
March 8th, 2005 08:11 PM #9
How much would a good torque wrench cost? Any shops you can suggest where I can buy this? Brands?
Thanks for the replies
- Feb 2005
- 34
March 8th, 2005 08:32 PM #10Originally Posted by ILuvDetailing
use your wrench or special tool na meron ka in tightening the sparkplug. when you feel na lumalaban na yung spark plug thread sa cylinder head (using your tool not just a hand tight), just add 15 degrees turn. same thing applies sa mabababang torque na fasteners. pag higher than 30Nm nagdadagdag na ko ng ilang degrees pa to meet the torque requirement.
VinFast VF 3
