Results 1 to 4 of 4
    i have just read sa maintenance manual na dapat daw i-tighten ang body bolts per 100k kms PM.
    my car has just reached 100k kms. i suspect this is the cause nung mga squeaks and langitngits that i've been hearing.
    how does one go with it? how is it done? can these be done at shops outside of the casa? any shops in las pinas/alabang areas which do this? what is the estimate cost of the service?
    thanks.
    May 2005
    terminology nila yan referring to the bolts beneath the car, like cross member bolts, various suspension bolts etc. it can definitely be done outside of casa. mura mura lang yan.
    the squeaks and langitngits might be coming from any part of your worn out suspensions system like shocks, ball joint, bushings, tie rod end, rack end and many others.
    Calltex does a decent bolt tightening job, costs around P200 AFAIK.
    Nov 2003
    any shop should be able to perform that job for you.
Tightening Body Bolts
