Results 1 to 10 of 11
February 8th, 2007 04:02 AM #1
if its the bearing you'll hear a humming sound that gets louder as you increase your speed. if it gets really bad it will seize like a stuck-up brake and you won't be able to drive it without letting it cool down. but i think that "thug, thug" sound is from your tires. check for uneven wear or bulges.
- Sep 2006
- 181
February 8th, 2007 08:41 AM #2
- Sep 2006
- 181
February 10th, 2007 06:15 PM #3hi sirs, just an update.
did the fastest fix and replaced the two front tires (they needed replacement anyway) but the sound is still there. will have the bearing checked.
February 10th, 2007 07:56 PM #4
Bakit di mo na lang pacheck lahat habang nandun ka't binubuksan yung bearings?
- Sep 2006
- 181
February 12th, 2007 08:51 AM #5chineck nila po nung nagpalit ako ng gulong pero dahil sa nagmamadali ako, hindi nabuksan. hinawakan lang po yung gulong ng dalawang kamay tapos ibinaling kaliwa't kanan at inalog. ala daw diprensya - duda ko kailangang buksan nga.
gonna make time for it next week, thank you sir.
OT, sana may mb din ako, kahit 124 o 201 hehehe
