Results 1 to 10 of 11
- Sep 2006
- 181
February 7th, 2007 04:02 PM #1hi people, could someone please help me. my 323 familia makes a thudding sound whenever its in forward motion. the faster i go, the faster it gets. (kasabay ng paggulong?) i inspected everything in the front undercarriage (the sound looks like its coming from the front left side) and i can't find anything out of place, the mechanics can't too. i even jacked the car up and rotated the left front wheel, nothing suspicious. unbalanced tires? cv joint? halfshaft problem? what bugs me is that when i brought it to cruven, the sound disappeared, grrrr. but its back now.
im worried that it may be dangerous. i have this nightmare that when im driving the wheel suddenly flies off..help naman
February 7th, 2007 04:13 PM #2
Try to check the front bearings. Sealed type yang mga yan pero baka sira na din. Ano ba model ng famila mo? nakakairita talaga pag may mga tumutunog-tunog na di mo mahanap lalo na pag sa may gulong. Feeling mo baka bigla na lang matanggal gulong mo.
- Sep 2006
- 181
February 7th, 2007 04:21 PM #3thanks sir for the reply.
oo nga sir, kakatakot na nakakinis. pano po chine-check yung bearings?
btw, its a 96 mazda familia (yung may ABS)
any more helpful suggestions?
February 7th, 2007 04:31 PM #4
Jack mo sia then hawakan mo yung mga gulong sa top and bottom niya. Then alugin mo siya, pag may play ibig sabihin may tama na yang bearing mo. Pa check mo na sa mechanik mo, then sabihin mo na may duda ka baka bearing ang may tama. Para ma sense ng mechanik mo na nakakaintindi ka sa maintenance para di ka nia tagain sa labor. Pag sira bearing mo, its better na ikaw bumili huwag na yung mechanic mo para makatipid ka.
- Nov 2006
- 122
February 7th, 2007 05:23 PM #5it happened to my corolla before and right i replace the front left bearing and thats it problem solved.Good luck bro.
- Sep 2006
- 181
February 7th, 2007 06:58 PM #6salamat po sirs jcastillo932 and three in xe
i'll have it checked tomorrow and will give an update
here's another question sirs, if it really is the bearing, how dangerous is this if kept unrepaired?
February 8th, 2007 04:02 AM #7
if its the bearing you'll hear a humming sound that gets louder as you increase your speed. if it gets really bad it will seize like a stuck-up brake and you won't be able to drive it without letting it cool down. but i think that "thug, thug" sound is from your tires. check for uneven wear or bulges.
- Sep 2006
- 181
February 8th, 2007 08:41 AM #8
- Sep 2006
- 181
February 10th, 2007 06:15 PM #9hi sirs, just an update.
did the fastest fix and replaced the two front tires (they needed replacement anyway) but the sound is still there. will have the bearing checked.
February 10th, 2007 07:56 PM #10
Bakit di mo na lang pacheck lahat habang nandun ka't binubuksan yung bearings?
A little ot: I disputed several charges credited to me a month ago and mptc finally corrected ...
cavitex easydrive error
