Results 1 to 8 of 8
    97 Lancer GSR
    Thud or tog-tog sound pag lumiliko na my small bumps. Ano kaya dapat palitan?
    Sep 2006
    Lancer din sakin eh, pa check mo ung bushing. di ko lam kung tama spelling pero un sabihin mo, sakin kasi pag lumulubak ng maliit may tumutunog parang tumatamang bakal, nagmumuka tuloy taxi, pinaayus ko ung bushing ayun parang bagu sarap, walang katok basta maayus ung shocks mo ha, malamang bushing, go and ask your velocity joint kung pati ung pagliko tumutunog ha. pero most likely ung bushing...
    pag lumiliko lang ba sir? check mo tie rod end or yung coil spring mo sa harap baka nawala sa pwesto. or pwede ring may kalog na ang rack and pinion mo.. pa check mo na sa iyong suking mechanic..
    ganun din problem ng 7g galant ko. may tug tug sound pag lumulubak. baka nga dalhin ko sa zee. magkano po ba pa inject ng bushing sa kanila and how much namn po cost ng replacement na bushing? tnx =)
    Quote Originally Posted by MAXBUWAYA View Post
    97 Lancer GSR
    yung kay sir Sprex eh "kruuggg-kruuggg-kruuggg" pag nag-accelerate while sayo naman sir Max eh "tog-tog" pagliko at kay sir Rogie eh metal to metal grinding noise (siguro "sckreeng-scheength"):-D
    katuwa talaga 'tong forum coz very descriptive yung mga threads kulang nalang eh actual sounds. anyway sakin dati toyota ganun din, bushing lang yung problema.
    Nov 2003
    as with most suspension sounds, it's better to have it checked than to describe it sa board. everything is interconnected sa suspension so it could be 1 or more than 1 part that is damaged.
    that happened to me too. sa bearing po yan. pagawa mo asap coz pag di naagapan mas malaki gastos.
    ball joint
Thud sound when lumiliko or nalubak ng maliliit
