Results 1 to 10 of 17
- Nov 2005
- 9
May 8th, 2006 12:27 AM #1mga master, newbie hir. just got a 97 lancer pizza tail. e wala po cyang tacometer. kano po ba pa install ng rpm meter? ok lang po ba na may ganun ako? hindi ba ko magmumukang ricey? kasi fuction lang talaga habol ko. ano po sa tingin nyo? feedbacks po are greatly appreciated. saka ano po ba tong mitsu ko? eto po ba ung gsr? sori la po kasi talaga ako alam.
May 8th, 2006 12:32 AM #2
Baka EL siya kasi walang tachometer.
As for the instillation part, antayin na lang natin mga experts. hehehe
May 8th, 2006 12:33 AM #3
sir, post po kayo pic ng car niyo.
if 2-door, GSR yan and 1.6L EFI with tach. if 4-door, maraming trim but based on the fact na walang tachometer sila, most likely EL po siya (1.3L carb engine). the GL (1.5L carb) and GLXi (1.6L EFI) had a tach na.
- Nov 2005
- 9
May 8th, 2006 01:47 AM #4opo. definitely EL po to. kasi po hinanap ko na ung taco di ko makita e. possible po bang malagyan ng tacometer ito? kano po kaya ang magagastos ko sa installation? and one more thing.. hindi po ba talaga to power steering? kasi ang tigas tigas nung manibela. TIA!
May 8th, 2006 01:56 AM #5
ang alam ko po pwede yan lagyan tacho, not sure lang po
anyway, let's wait for others to reply.
and yes, pawis steering pa po siya.
May 8th, 2006 08:19 AM #6
Akala ko about fastfood yung thread, may taco & pizza eh, hehehe
Seriously, you can attach an aftermarket tachometer, kasi most modern engines, may naka-abang naman na wire for the tach signal
May 8th, 2006 10:06 AM #7
pwede yan. tap na agad sa ECU to get the proper rpm readings for the aftermarket tach.
- 10,620
May 8th, 2006 01:54 PM #9
i have a lancer gsr bro, may tach na sya eh, pero gusto ko palagyan ng tachmeter na may autoshift light. ok lang ba yun? ano difference nya dun sa built in tac ko and dun sa separate tach na may auto shift light? mag kano pa isa nito? gusto ko lang kasi sya for good looks lang. ok lang ba? thanks.
May 8th, 2006 02:03 PM #10
Originally Posted by Nautilus
actually wala syang kaibahan dun sa stock tach ng lancer. maganda lang talagang tignan.
i think this costs around 3-3.5k.
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
