Results 1 to 6 of 6
    Puede ba dalhin ang kotse sa casa and have an MUT test para ma-determine kung may impending trouble? I recently changed my ecu(mitsu) and i thought that it wouldn't be busted if something didn't cause it to break down(like faulty sensors). I don't want the same ecu problem happening again so i'm thinking if an early MUT test would help. thanks.
    I've done a little research at the internet and found out that there are simple ways to determine the trouble in your car, i. e., if you can access the data connector. All you need is a voltmeter, and by observing the beeps and flashes the "CHECK ENGINE" light indicates.
    but you'll also need the factory manual for the meaning of these beeps and flashes....
    for me old school cars works best!
    Yup, meron info sa internet about the beeps and flashes.
    http://www.troublecodes.net/technical/
    Jan 2004
    Uh, question lang po. Ano po ang MUT?
    Nag-try ako sa acronymfinder.com parang hindi related yung mga lumabas.
    Salamat!
    Apr 2004
    it must be mitsubishi specific.
    ang alam ko sa nissan ang equivalent nito is CONSULT.
Can an early MUT test detect an impending trouble?
