Puede ba dalhin ang kotse sa casa and have an MUT test para ma-determine kung may impending trouble? I recently changed my ecu(mitsu) and i thought that it wouldn't be busted if something didn't cause it to break down(like faulty sensors). I don't want the same ecu problem happening again so i'm thinking if an early MUT test would help. thanks.
I've done a little research at the internet and found out that there are simple ways to determine the trouble in your car, i. e., if you can access the data connector. All you need is a voltmeter, and by observing the beeps and flashes the "CHECK ENGINE" light indicates.
