Page 1 of 5 12345 LastLast
Results 1 to 20 of 90
    can i spray wd-40 lubricant on the engine compartment? during my start-up, every morning, the moving part on my engine that is attached to the gasoline pedal is sticky, it won't go back but if the engine is already heated up, that thing is normal again. i'm afraid to spray wd-40 on it because it might cause sparks as warned by the label on the can. is it ok to spray it or not. please help, thanks....
    spray it but don't leave it on... spray mo sya like a cleaner... let it soak a little then wipe it off with a cloth... it'll still lubricate the surface in addition to cleaning it.
    mayroon talagang specially made spray dyan ah....i think cycle ang brand...i use it sa moving parts ng carb ko.....
    Quote Originally Posted by ily_j02
    Baka ganyan talaga yan. Medyo high ang rev pag cold to get the engine to it's operating temperature. Then pag naabot na back to normal na siya.
    ano ba car mo? IMO what your referring to is the auto-choke that automatically increases your idle during a cold start but gradually returns to its normal idle position once the engine reaches its normal operating temp...
    Hindi naman siguro mag i-ispark..
    Kaya lang baka magluwagan mga igang bolt/nut na affected diyan pag tagal tagal ..
    Pa check mo na lang baka may diperensiya pedal mo..
    thanks for your replies, my car model is an '91 lancer GLX, i bought it 2 years ago and it is only now that i experienced this, i don't think that its the auto choke because my car doesn't have one, whenever i start my engine, i pump the gas pedal at around 1 to 1.2k revs until temp normalizes and then release the pedal but the idle is very high, i have to quickly pump the pedal so that idle will go back to normal. even when i'm already running, this still happens, i think i have to have it checked with a mekanik para sigurado, thanks again....
    Check the spring in the pedal. Change your accelerator cable. Baka stuck up na yan.
    If its EFI ganyan talaga yan. This is because it will bring the engine to STP (standard operating temperature and pressure) in the soonest possible time. Normal yan. Let it idle for 1-2 minutes.
    It might also be that you need a tune-up / change-oil already. Happens to me everytime my cars near the 5000km servicing.
    WD-40 is OK. Mangangamoy lang engine bay mo but no sparks. I do it palagi. ;)
    ok naman wd-40 ilagay recommended pa nga sa spark plugs di ba.
    ok nga itong wd40, dami pakinabang..
    Aug 2005
    yep ayos ang wd40 pang cleaning and lubricate. mostly spray ko sya outer ng carb... I also have a carb cleaner para sa inside..
    OT: wD40 partner ng tamiya 4wd ko yan nu.on Highschool pa ako
    Nakow..........nabuhay ulit, hinalukay sa baul!
    Anyways, eh sa disc brakes, ok din ba WD40 pantanggal ng kalawang?Napansin ko kasi medyo may portion na may kalawang yung disc brakes ko.
    Oct 2004
    ...just be sure you don't spray WD40 to your fan/alternator/timing belts... as it will shorten their lifespan....
    Aug 2006
    boss may nabibiling brake cleaner. wag mo gagamitin ang wd-40, baka di kumapit brakes mo
    hehe kahit luma may pakinabang pa rin..
    Apr 2008
    Guys,
    WD-40 safe ba sa Car Paints?
    May 2007
    Quote Originally Posted by afrasay View Post
    True. Change that cable or?
    Before changing on it why dont you try working on just a bit. Your problem have two possibilities...maybe the throttle butterfly shaft is sticking in the throttle chamber, or the throttle cable is binding up. What you can do is disconnect the throttle cable to the throttle shaft and the gas pedal. Then move the cable back in forth to make sure it slides back and forth easily. If not you will have to replace it. If the cable is okey, then you need to give the throttle body a gooooooooood cleaning
    Jul 2013
    Saw a YouTube video na ginamit yung WD-40 para sa railings ng windows, to "prolong the life of Power Windows" daw
    Di ba sya nakaka-sira ng tint?
    Not sure about tint, but it has to be silicone based so it won't damage the rubber seals. Yung regular WD40 spray lubricant petroleum based yun. Meron din silang silicone based lubes.
    Edit:
    It looks like WD40's silicone sprays also have petroleum distillates in them. So still not safe for plastic/rubber.
wd 40
