impossible naman na hindi pumapasok yung hangin sa makina. basta nagreredondo that means may hangin (since the engine is basically an air pump).
if the plugs are wet from gas it means that there is no ignition happening which is what is supposed to ignite the gasoline. either that, or the injectors are flooding the plugs so hindi nya ma-fire.
pero yung sinasabi na walang pumapasok na hangin is BS. that will only happen if you seal off the whole intake.
