Results 1 to 10 of 10
- Feb 2007
- 12
May 16th, 2007 04:26 PM #1Mga bossing,
Need po ako ng help kasi ayaw mag start ng Car ko. It's a Honda civic VTI '97. It only cranks over pero ayw magtuloy mag start. Ano kaya ang pwede kong i check. Na check na ung mga fuse mukhang OK naman. Newbie lang po sa kotse. any suggestions po. gusto ko nga sana dalhin sa mechanic kaya lang nakapark sa loob at mahirap ilabas pag tinulak, ako lang lalaki sa bahay. Ala naman ako alam na mekaniko na marunong sa honda sa place namin, bagong lipat lang kasi. thanks po
May 16th, 2007 04:48 PM #2
check mo battery baka failed na also mga terminal... if not pa din, hanap ka ng mekaniko near your area para ma check kung ano pa problem ng car mo..
- Jun 2004
- 1,311
- Feb 2007
- 12
May 16th, 2007 05:33 PM #4
May 16th, 2007 06:46 PM #5
check the most popular thread in the maintenance section:
http://tsikot.yehey.com/forums/showthread.php?t=29335
pag nag-ignite during ignition, mechanical / fuel system problem. pag di nag-ignite, electrical problem. listen carefully sa clicks.
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 20th, 2007 11:32 AM #6kung malakas mag redondo pero ayaw tumuloy it's probably either the fuel pump or the ignition coil na nga.
- Feb 2007
- 12
May 22nd, 2007 01:11 PM #7nacheck na po ung ignition coil and fuel pump ok na naman po daw. sabi ng honda mechanic di daw pumapasok ung hangin and sasa ung spark plug ng gasolina. eto po ba ung low compression. ano po ba gagawin pag eto ung problema.
- Nov 2003
- 3,848
May 27th, 2007 09:29 AM #8engot yung mechanic...
impossible naman na hindi pumapasok yung hangin sa makina. basta nagreredondo that means may hangin (since the engine is basically an air pump).
if the plugs are wet from gas it means that there is no ignition happening which is what is supposed to ignite the gasoline. either that, or the injectors are flooding the plugs so hindi nya ma-fire.
pero yung sinasabi na walang pumapasok na hangin is BS. that will only happen if you seal off the whole intake.
May 27th, 2007 10:23 AM #9
Tingin ko dyan ang problema mo eh yung battery. Ang sasakyan na natin ngayon ay electronics na...hindi na kayang supplyan nang batterya ang mga yun kaya ayaw magtuloy tuloy ang pag start.
subukan mong maki usap sa kapit bahay na may kotse din at e series yung battery para ma start mo yung sasakyan. kailangan naka andar yung kotse noong kapitbahay mo...bago mo start ang sasakyan.
Kung sakali man umandar ang sasakyan mo...kahit na ipa check mo yang battery mo sa isang shop..sasabihin ay ok pa.
- Feb 2007
- 12
May 28th, 2007 10:51 AM #10ok na po ung kotse ko. pinalitan lang ng spark plug nag start na. medyo kinabahan nga ako kasi unang sabi sakin eh overhaul daw. nung dinala ko sa ibang mekaniko nagpalit lang ng sprk plug umandar na. buti na lang di ko agad pinasok sa casa
Nakakakilabot yung bagong srps taking into consideration na mag-10 years na ang current model neto.
All New Toyota Hilux
