Results 1 to 8 of 8
    Sep 2006
    This is the problem... madaling i start ung car even it is cold start as long as nde mo pa ngagamit ung car... But when u have started it already and driving for an hour then turn off your engine, ayaw na mag start uli... Lagi ako nadadali pag nagpapa gas ako... Kc if i am driving for 30 mins syempre mainit na ung mkina then pag inistart ko ayaw na muli...
    What could be the problem??
    May 2005
    This sounds like an ignition coil problem.
    What type of car you have anyway?
    Jul 2005
    when you try to start it again what sound do you hear if thick thick maybe its the starter
    Oct 2004
    Quote Originally Posted by utk505 View Post
    Could also be the starter soleniod....
    Jul 2005
    yap solenoid thats what happen to me , pokpok lang katapat or better yet have it inspect for dirt or damage
    Nov 2003
    you should be able to get a replacement solenoid in most cases. pero if the starter is ok... take a look at the ignition system.
    Sep 2006
    I think di nman cguro ung starter... kc may redondo nman cya.. mlakas redondo nya... ive changed d battery yesterday... i dont know wat could be problem... ignition coil, solenoid, linisin daw ung starter... mdmi cla recommendations... ano b pinakamalapit na problem??? btw my car is civic esi...
    Apr 2006
    Mas maganda madala mo sa mekaniko mo to identify the problem of your car. Mas maganda rin matitiyempuhan nila na ayaw umandar para madali nila makita kung bakit ayaw umistart. It could be igniton system or fuel system ang problema. Sabi mo lagi kang nadadali pag nagpapagas ka, isang question yan. Pede rin wiring baka may loose ground ka kaya pag nagiinit nagkukulang ng supply ng ground.
    Talagang maraming pedeng pagmulan ng sira kaya skit ng ulo maging mekaniko.
Starting
