Results 1 to 10 of 26
- Jan 2008
- 42
January 20th, 2008 10:55 PM #1Chief i need your help. My car is a lancer 93' model and i bought it 2nd hand after a few months mejo lumabas na yung kalampag ng front suspension, so i decided to get some advices to one of the automative shops near our place and was advice to replace shocks ball joint and bushing
nawala siya after a day then on the next day nakakarinig ako ng lagatok sa right side and squeeking sa left side but not really sure kung san talaga nanggagaling ang squeeking pero yung lagatok 100% sure ako nasa right side
nagpa check ako uli and ask 3 shops for opinions the
shop number 1
(lagatok right side )
shocks daw and problema na mejo nag doubt ako dahil sa kakapalit lang ng shocks, (at squeeeking sound )
sabi shocks din daw at the back
shop number 2 ( lagatok velocity daw sa front right side)
and squeeking sound is sa assembly bushing rare
shop number 3 ( walang findings sa lagatok di daw nila naririnig
and the squeeking sound is front left assembly suspension daw kailangan palitan
pls help me or if u can refer me to a very reliable shop that cant remove the squeeking and lagatok sound
- Jan 2008
- 42
January 21st, 2008 01:45 AM #3
tnx for that info chief
additional info about the lagatok sound
when we checkd the right front suspension the mechanic found some greese sobrang dami and yung boots sira na nabasa ko sa ibang thread na CV daw problema nun, kasi minsan pag lumiliko ako lumalagutok o kahit straight and takbo at uneven yung daan paminsan minsan lumalagutok
January 21st, 2008 10:20 AM #4
pre bring it to cruven. have them check it.
had this problem last week. squeeking sound on my front right, turns out the the ball joint on the lower suspension arm has no more grease.
lancer rin auto ko.
- Jan 2008
- 42
January 21st, 2008 10:59 AM #5sir ang sabi naman nung isang talyer baka masyado daw maliit ang sukat ng balljoint kaya nag sqesqueak kailangan daw iwelding ang butas na kinakabitan ng ball joint or talagang replace na yung arm suspension im not really sure about the name of the part pero dun nakakabit ang ball joint
is that possible?
- Jan 2008
- 42
January 21st, 2008 11:06 AM #6mga fellow tsikoteers need your help, sana makapag bigay pa kayo ng other info regarding this issue. tnx po sa advices nyo chief.
January 21st, 2008 11:24 AM #7
^^ did they remove the suspension arm before they told you that that is the problem? I'm not sure if welding would solve it. replace the whole arm might do the trick pero try having it re-greased first malay mo gumana. bring it to a competent shop, try cruven, as far as my ride is concerned, they know what they're doing
- Jan 2008
- 42
January 21st, 2008 11:47 AM #8
boss danejr tnx much for the info, actually they didn't remove the suspension arm, hint lang nila na posibleng suspension arm dahil kakapalit ko lang ng brand new na ball joints at bushings, ill try cruven, baka kaya nila remejuhan kasi isang advice nung talyer kung di welding replace talaga ang suspension arm which will cost me 1.2k for the arm and 750 for the labor plus camber allignment 1,200
diba standard naman ang mga sukat ng ball joints bakit sinasabi nila baka daw maliit ang nabili kung size ng balljoint kaya nag sqesqueak
January 22nd, 2008 03:53 AM #9
check mo din power steering fluid mo baka nagleak (based on my experience)
weird kasi sakin yung nagkakaleak nababasa yun CV ball joint (pati yung parang boot) lakas talaga ng squeak sound parang anfra na tunog so yung napa fix ko na yung tulo (replaced hose) ayun nawala hangang ngyon ok na
lancer din car ko bro pizza nga lang
try mo rin pala i-jack ang affected area tapos test drive mo kung nabawasan o nawala yung squeak sound baka re-grease lang yan
cruven bro ok paestimate ka muna, mag road test din kayo para ok
- Jan 2008
- 42
January 22nd, 2008 07:46 AM #10------------------
tnx chief sa info, mine is just m/t, nag pa check up ako sa dalawang talyer, and they see no problem with the velocity kasi pag tinetest drive nila at todo liko wala siyang lagatok, with regards to the lagatok sound on the right side baka bushings lang daw, but how come may grease na nagkalat at yung boots mejo punit na?
sa squeking sound yung ball joint mejo maluwag daw, pinakita sa akin ng mechanic yung pwesto ng ball joint at mejo maluwag nga yung pagkapwesto na sa suspension arm. sa tingin nyo yun kaya ang dahilan ng squeaking sa front left suspension ko?
Daming issue ng SU7:grin:
Xiaomi E-Car
