Results 1 to 14 of 14
    Oct 2003
    i have a set of splitfire sparkplugs in my engine for 2 1/2 yrs already. gaano ba katagal ang lifetime neto? at kelan ako magpapalit? kasi nun tinignan ko looks like new to me---halos ganun pa rin itsura nilinis ko lng yun itim sa gilid maputi na uli. thnx
    Oct 2003
    yun version ko nga pala ng splitfire ay yun black at blue yun nasa karton, sya yun mas mura sa platinum ba yun and it has a V-shaped electrode
    Aug 2003
    Diba may v-shaped sya na nakaliko then may tip na pointed. Yung tip na yun pag pudpod na it means you have to change sparkplugs na kasi it is already worn out na and mahina na spark o kuryente.
    Dec 2002
    I've seen plugs that only ran 5k kms in a year but needed changing. If you've done 10k kms on the splitfire then suggest you change them.
    Try NGK or Denso instead- better performance than the splitfire plugs.
    Oct 2003
    nakalagay ksi sa box 36 months warranty, di ko sure kng good for 3yrs sya
    Mar 2004
    personally i prefer splitfire spark plugs over the ngk ones for my car. the last set that i bought lasted for about 2 and a half years din. mag 2 years na yung ginagamit ko ngayon and wala pa din problem. for me sulit na cya kasi mahal na yung mga ngk ngayon eh.
    Oct 2003
    kicker paano ko malalaman kung magpapalit na ako? ok naman ang andar at yun isura mismo ng plugs
    May 2004
    Ingat sa mga Splitfire plugs kasi na fake ako nyan sa banawe. I used Denso IRIDIUM PLUGS for my 2.4L 16V DOHC Super Charge Engine got no problems. Last up to 36Months.
    Jul 2004
    nagkaroon po ng crack yung ceramic insulator yung isang spark plug ko NGK R pero ok pa naman sya, kailangan ko naba palitan yung may crack? isang set or yun lang may crack? salamat po!
    Aug 2004
    I'm also using this type of spark plugs pero 1 week pa lang. according to their site's FAQs (quoted below), it's 36 months but it's totally up to you.
    How long will SplitFire Spark Plugs last?
    A: SplitFire, Inc. guarantees that SplitFire Spark Plugs will meet or exceed your automotive or truck manufacturer's spark plug performance standards in a properly tuned automobile or truck with a non-modified engine for 36 months, regardless of mileage driven, or we will replace the spark plugs. (See our Warranty information sheet for full details of this limited warranty.)
    Jul 2004
    Question po ulit: Yung dalawang plugs ko normal yung sunog (tan,brownish) pero yung dalawa soft black carbon sa insulator and electrodes. ano po kaya problem nito? wala na sa timing?
    Aug 2004
    dack... u need to change u cracked spark plugs... ma ground ka nyan... voltage running per plug is 40,000 volts minimum.
    sa question when to change the plugs just check for the gap of your plug... usually mga .0035" ang clearance. kung ala na sa clearance palitan na.
    Aug 2004
    dack...
    the tan grayish color sa plugs more ibig sabihin nun nasa normal operation ang plugs more.
    the other 2 plugs naman ibig sabihin nun me barado ka maybe sa injectors or sa fuel filter. so if i wer u change ur fuel filter first.
    Jul 2004
    .. dudepare,
    maraming salamat po! papalitan ko nalang muna yung may crack na plug. then check ko yung fuel lines and filters kung marumi na.
splitfire sparkplug question
