Results 1 to 8 of 8
- Aug 2015
- 862
September 24th, 2015 03:54 PM #1I have 07 altis AT at 83k kms. Nakaka rinig ako ng mejo high pitched sound pag cold start duda ko ung drive belt or serpentine belt. Pero nawawala ung tunog pag mejo uminit na makina. Parang umiikot na sound.
I dont think i encounter any trouble sa alternator, no symptoms of fault sa electricals. Kahit patay ang AC meron din nung tunog, so abswelto ung compressor ko tama? Pinalitan kasi ng surplus last year yun.
Stock na serpentime pa din naka kabit. Is that it?
September 24th, 2015 04:04 PM #2
- Aug 2015
- 862
September 24th, 2015 04:19 PM #3
September 24th, 2015 04:21 PM #4
September 24th, 2015 04:28 PM #5
pag screeching - belts
pag squeaking - pulleys
better have that checked na din. pero at your symptoms, it has to be the belt.
- Aug 2015
- 862
September 24th, 2015 04:31 PM #6You've all been very helpful. I will try the water spray method napanuod ko sa youtube from belt manufacturers for some diy diagnosing. Babalitaan ko kayo soon. Thanks again
September 24th, 2015 04:37 PM #7
its only a temporary solution, imho, but sooner or later, the sound will go back (assuming its the belt).
only solution is to replace the belt.
- Aug 2015
- 862
September 24th, 2015 07:05 PM #8
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
