Results 1 to 8 of 8
SiRaNeko
- Jan 2003
- 973
June 9th, 2003 09:56 PM #1when i press on the washer button, wlang labas na tubig . wla rin yung tunog na parang nagpapapump 8O
any body know where can i have this repaired/checked? :?
June 9th, 2003 09:58 PM #2
check the water reservoir baka la ng laman... pwede ring mabara yung butas ng nozzle... try mo gamitan ng safety pin pang tanggal ng bara sa butas.
if all else fails, try mo na nga patingnan sa mekaniko.
HTH
- Apr 2003
- 526
June 9th, 2003 11:00 PM #4had that exact same problem. punta ako shop to have it check. sabi sa akin, sige nga try mo, ayun nagpump yung hayup na wiper washer.
:mrgreen:
June 10th, 2003 08:49 AM #5Originally Posted by buknoy2002
tusukin mo ng karayom yung labasan ng tubig. meron lang mineral deposits na nag-form dun sa butas nun.
ganyan din sa akin dati, tinusuk ko nga ng karayom, yun labas ang tubig.
June 11th, 2003 12:33 AM #6
1. Check kung gumagana o tumutunog ang pump. If wala then check for fuse burn-out or replace the pump.
2. Karayom technique sa opening ng washers to dislodge precipitates.
3. Pisil technique on all rubber hoses from reservoir to washer to dislodge precipitates.
4. Disassemble plastic connectors in between rubber hoses and use karayom technique to again dislodge precipitates.
5. Drain reservoir of tap/mineral water and use distilled/rainwater as washer fluid to prevent this. Mahal lang nga distilled water.
:D
SiRaNeko
- Jan 2003
- 973
June 11th, 2003 05:45 AM #7thnx for the replies... will try your suggestions.. sna nga fuse/karayom lng problem8)
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
