Results 1 to 10 of 23
June 27th, 2015 05:11 PM #1
Guys ask ko lang kung pano malalaman kung oblong na yung gulong. Nagpa check kasi ako kanina sa servitek dahil nag wi-wiggle yung sasakyan pag umaabot ng 80km. After checking sabi oblong na daw gulong ko. Acceptable sana kung isa o dalawa. Pero yung 4 na gulong ko daw oblong na!. 30k km ko palang nagagamit yung gulong saka 2012 yung manufacturing date nya. Neuton pala tatak ng gulong ko. Thanks!
- May 2014
- 1,319
June 27th, 2015 05:47 PM #4
oblong tires should be obvious if you mount then let them spin at the tire balancing machine. kitang-kita yan kahit naked eye.
- Jun 2005
- 3,774
June 27th, 2015 05:47 PM #5magpa balance ka ng gulong. dun pa lang makikita mo agad kung oblong ang gulong. okaw mismo makakapansin nun
June 27th, 2015 06:23 PM #6
Gamit man or hindi ilan years ba life span ng goma?
June 27th, 2015 06:35 PM #7
- May 2014
- 1,319
June 27th, 2015 06:44 PM #8AFAIK 6 years from the date of manufacture ang ginagamit, regardless kung kelan kinabit after the fact. But this is more to do with elasticity ng rubber. Kaya may mga reserve/spare tire ka mapansin na never masyado nagamit pero puro crack na dahil malutong na goma, expired na bale at delikado na ibyahe baka pumutok.
Correct me if I am wrong though.
Oblong usually cause is improper tire pressure over long periods of time of use/loading lang naman diba? May iba pa ba cause?
June 27th, 2015 06:47 PM #9
Yung "tusok" vulcanizing repair nakaka oblong din daw.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
