Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Dec 2009
    Guys ask ko lang kung pano malalaman kung oblong na yung gulong. Nagpa check kasi ako kanina sa servitek dahil nag wi-wiggle yung sasakyan pag umaabot ng 80km. After checking sabi oblong na daw gulong ko. Acceptable sana kung isa o dalawa. Pero yung 4 na gulong ko daw oblong na!. 30k km ko palang nagagamit yung gulong saka 2012 yung manufacturing date nya. Neuton pala tatak ng gulong ko. Thanks!
    Like any serious sickness, get a second opinion, even a third
    Wiggle ang buong kotse o manibela?
    oblong tires should be obvious if you mount then let them spin at the tire balancing machine. kitang-kita yan kahit naked eye.
    Jun 2005
    magpa balance ka ng gulong. dun pa lang makikita mo agad kung oblong ang gulong. okaw mismo makakapansin nun
    Gamit man or hindi ilan years ba life span ng goma?
    AFAIK 6 years
    AFAIK 6 years
    AFAIK 6 years
    AFAIK 6 years
    AFAIK 6 years from the date of manufacture ang ginagamit, regardless kung kelan kinabit after the fact. But this is more to do with elasticity ng rubber. Kaya may mga reserve/spare tire ka mapansin na never masyado nagamit pero puro crack na dahil malutong na goma, expired na bale at delikado na ibyahe baka pumutok.
    Correct me if I am wrong though.
    Oblong usually cause is improper tire pressure over long periods of time of use/loading lang naman diba? May iba pa ba cause?
    AFAIK 6 years
    AFAIK 6 years
    Yung "tusok" vulcanizing repair nakaka oblong din daw.
    Dec 2009
    Quote Originally Posted by 17Sphynx17 View Post
    Bandang harap lang sir.
Signs na Oblong ang gulong
