Results 1 to 17 of 17
    Mga bros, obvious ba ang difference ng OEm vs replacment taiwan?
    Dec 2008
    Generally not from afar kung same design. As you get closer, some details may be different.
    does the side mirror involve remote adjustment mechanism, or is it just a side mirror with manual pawis adjust?
    also, take a hard look at the taiwan model, if it looks just like oem.
    Hindi rin naman pansin pinagkaiba bro.
    Sent from my Alcatel Onetouch Pop 3 (5) using Tapatalk
    Quote Originally Posted by stagea View Post
    thanks master! feedback kasi nung store clerk when i called earlier, mas matibay lang daw orig; but looks the same daw.
    Dec 2008
    Yung finish minsan hindi exactly the same, say smooth versus finely textured. Yung markings obvious na magkaiba din. Kung ipepaint mo then macover din naman. Check for flashings sa pagcast.
    manual bro
    mukhang need ko talaga puntahan nalang to see for myself
    Quote Originally Posted by rodetor View Post
    sana nga bro, medyo OC kasi ako eh :D
    ok lang master siguro; nag inquire ako for vios nasa 1.4k cheapest in paranaque vs 1.5k and up sa banawe and manila/taft stores. so yung pair na palitan ko nito, incase malayo talaga itsura
    Dec 2008
    Mura na. A mirror alone will fetch that much sa OE madalas, baka more pa kapag expanded view/aspherical mirrors kailangan mo.
    ito ba yun parang wide angle master?
    Dec 2008
    Hindi pareho ang grado vertically vs horizontally ng aspherical mirrors kaya wider ang view. Pumapayat ang reflection.
    ah gets ko na master, parang yun ford nasakyan ko minsan. akala ko nga nung una sticker hehehe
    Jun 2012
    Naduduling ako dati sa ganun. Nakakalito. Although almost an hour ko lang nadrive
    Sent from my SM-A9000 using Tapatalk
    update ko lang thread ko, sakali may kailangan
    so far 2 replacement (taiwan) nabili ko
    isang 1.4k na pangit yung mirror (as is ang view), though sakto naka ang bolt in sa auto; ibang iba ang itsura nya sa OEM.
    isang 2.8k na OEM yun view ng mirror, sakto lang din yung bolt in sa auto; quality quality of plastic is obviously inferior to OEM.
    OEM side mirror cheapest is * 6.8k upto 8.8k
    ill post pics nung mga nabili ko ^_^
    Sorry to hijack this thread. May I know saan po kayo nakabili ng sidemirror? Looking for sidemirror kasi for Sportivo. 16k kasi sa casa since kasama daw mismong frame.
    Quote Originally Posted by eannemay View Post
    not sure, pero yun nabilihan ko ng matinong replacement, sa valenzuela pa eh
    ito na canvass ko sa vios noon;
    cheapest OEM 6.8k (order basis)
    cheapest replacement 1.4 - 1.5kk (sablay mirror, and itsura, pero sakto fit)
    replacement na pareho ng OEM 2.8k halos pareho ng OEM pero plastic quality is OK lang
Side mirror assembly replacement vs OEM
