Results 1 to 7 of 7
    question lang guys, anu ung screeching sound lalo na kapag kaka-start lang ng sasakyan?? specially if you try to "kabig" ung steeringwheel? kasi panacheck ko sa mekaniko dito samin, may pinihit lang siya and then aus na, hindi ko na naitanong kasi nagmamadali na din ako kanina... anu kaya yung pinihit nya... alam nyo ba ito guys??
    up ko lang po....
    Jun 2004
    baka sinikipan lang yung belt para sa alternator or power steering
    Nov 2003
    ano pinihit? yup, he probably just tightened the belts.
    karaniwan na lumuluwag naman is aircon belts.. pero di ko din sure sa ibang cars.
    Jun 2007
    baka dun sa may idler pulley yung sinikipan
    kaya maingay maluwag belt mo
    did you check for cracks? baka time to change narin
    As the others have said, it's most likely a loose belt.
    In order to "fix" this, your mechanic could've adjusted the tensioner so that the belt would be under proper tension again.
    Be sure to keep an eye on it as the belt could be old and you'll eventually need to replace it.
    Hope this helps.
Screeching Sound - Cool Startup
