Results 1 to 10 of 12
May 29th, 2007 10:04 AM #1
mga sir sino po sa inyo taga batangas?
wala po kasi ako mabilhan ng wiper ng lancer ko. nalibot ko na mga surplus shop sa sto. tomas, tanauan, malvar, at lipa wala sila maibigay sa kin. san po kaya meron? iisa kasi wiper arm ko...pang toyota pa...laki na nga ng scratch sa shield ko!
FrankDrebin GuestMay 30th, 2007 10:14 AM #4
Wiper Blade po ba or Wiper Arm?
Kapag blade lang, sa inyong pinakamalapit na suking Auto Supply mayroon niyan.
Kapag arm, kung wala kang makita sa mga Surplus shop sa inyo then Banaue, QC is your only hope.
June 4th, 2007 11:32 PM #5
June 5th, 2007 05:42 PM #6
Sa parian calamba, nakapaghanap ka na chief?
After checkpoint, turn left, then ilang meters lang sa right side, may shop dun ng surplus parts, try mo dun.
If wala , try mo sa AMCAR sa real calamba, i'm sure if walang stock, pwedeng i-order.
Or sa tapat ng AMCAR mismo, may isang shop na specialized ang mitsubishi replacement parts, baka mas mura dun.
hth
June 9th, 2007 05:39 AM #7
June 9th, 2007 10:56 PM #8
What Lancer model? box type, singkit, itlog, pizza...? Any wiper arm will do provided akma dun sa mga spline. If medyo mahaba ma adjust mo naman yun by removing the lock then pushing the upper part of the arm in. Better to buy two of the same type.
- Jan 2007
- 4,459
June 9th, 2007 11:20 PM #9Pasingit lang, san pa meron sa QC aside from Banawe? Ung sakin kasi, medyo may kalawang na, and medyo malabo pag umuulan. Hindi na clear.
June 10th, 2007 12:23 PM #10
Try out the newly designed wipers, much easier to install and use. its like a full rubber wiper that will hug any shape of your cars windsheild (Means Safer to use without metals on it). Like the Bosch ICON brand but its really a hard to find brand. Mine is a sandolly brand works fine and much better than the old types of metal frame wipers..
Auto Shops in SM Malls don't have it before, not sure right now. You can find one of this at any Robinson Malls or any shops in Banawe Area..
Check:
www.sandolly.com
http://www.teamrage.ph/forum/viewtopic.php?t=2490
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
