Results 1 to 3 of 3
    diba sabi if you have a high mileage car then when you used a fully synthetic oil eh nagkakaroon ng leak, saan usually nag leak? I know one place is the valve cover gasket, san pa yun iba, yun oil seal san ba yun? thanks
    Jul 2006
    Marami.
    Crankshaft seals, valve cover seals, oil filter seals, possibly valve stem seals if they're also worn, etc. Any particular spot in your car that's leaking?
    Nov 2003
    you can leak from any or all of the seals pero you won't know where till it starts.
saan usually ang oil leak?
