Results 1 to 7 of 7
- Sep 2005
- 29
May 27th, 2007 11:27 PM #1Just want to ask if anyone had some ideas on this one.
I had referred my problem here pertaining to a clutch problem (may drag sa pag primera) and just as adviced, the problem was with the pressure plate. Pinalitan na rin ang clutch disk and release bearing. Okey na sana kaya lang I noticed this whinning sound on reaching around 40kph and onwards. Sumasabay siya sa tunog ng makina. Para bang sa M35 (6x6 truck ng military) na ang muffler ay nasa itaas. Ganun na ganun ang sound pero mahina lang. Any inputs would be appreciated. By the way, my vehicle is a revo gas. TIA
May 28th, 2007 10:39 AM #2
whinning sound on reaching 40 kpm? probably unbalanced wheels or worn out wheel bearings. better check kung related sa clutch yung problema. pa-diagnose mo kay zee kung san nanggagaling yung tunog
- Nov 2006
- 299
May 28th, 2007 10:50 AM #3bago mo pinalitan ang clucth and release bearing,andyan na ba yung whinning soun?
- Nov 2006
- 299
- Sep 2005
- 29
May 29th, 2007 12:25 AM #5Salamat sa mga nag reply. The sound started just after the clutch repair. I doubt if it's related with bearing or with alignment kasi ang tunog eh sumasabay sa pag apak mo ng gasolina. As you rev, sumosunod din ang whinning sound. Anyway, thanks a lot.
- Nov 2006
- 299
May 29th, 2007 06:53 AM #6try mo daw muna idiagnose ang release bearing.
to diagnose if it is a faulty throw out bearing/release bearing:
set the parking brake for safety.
shift the lever to neutral position.
start the engine and let it run to idle.
depress the clutch and rev the engine from idle to 1000 to 1500 to 2000 rpm hanggan sa makuha mo yung rpm ng 40 km/h (which is the whinning sound can be heard).
if you dont hear a whinning noise at this time,that indicate a good release bearing.baka nga out of alignment ito.misalignment kasi ang cause ng bearing (except release bearing) and other parts ,specialy pressure plate to get bad
DIY to death!
- Jan 2003
- 451
May 29th, 2007 08:40 AM #7Ano ba ride mo? FWD ba? If it is, then they would've had to remove the halfshaft in order to bring down the transmission. So pwedeng nagalaw yung bearing either nung pagtanggal or pagbalik. It's remote, but still possible since the symptoms you describe usually point to the wheel bearing.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
