Results 1 to 10 of 15
- Apr 2007
- 42
November 16th, 2007 11:53 PM #1patulong naman po...
ganito po...pagstart po ng engine akyat rpm more than 2k then unti-unti bababa around 1000-1200, same thing when aircon is on, ugong talaga makina nito.
then pagpasok sa 1st gear akyat ulit rpm morethan 2k w/o steeping the gas pedal, but this time hindi na bumababa sa 2k yong rpm kahit irelease clutch pedal. hindi na nga po nahihirapan umandar e sa sobrang taas ng rpm.
dinala na po sa mekaniko pero sagad na raw idle adjusment.
ano pa po kaya pwede gawin para mapababa rpm nito??? lakas kasi sa gas e.
'96 mitsu lancer itlog po yong oto and kakabili lang po last week.
TIA
November 17th, 2007 12:02 AM #2
Check your idle up switch and vaccuum. ALso yun mechanicals (springs and all) ng carb (i assume) and also your accelerator cable baka madumi na at puros kalawang kaya di maitulak ng spring sa dulo.
- Apr 2007
- 42
November 17th, 2007 12:45 AM #4
ah ok. check mo idle control valve or clean mo butterfly ng intake mo. check also maf sensor.
November 17th, 2007 02:56 AM #5
* afrasay......
good answer! Keep it up.
* grantt....... You car is fuel injection as you stated. At any circumtances DO NOT touch that HEX SCREW to adjust idle, that unit is PRESET at the factory and cannot be changed setting wise. Try cleaned the throttle plates and motor vac using carb cleaner.
November 17th, 2007 11:54 AM #6
maari meron pumapasok sa engine mo na un-metered air and the ecu is adding fuel to compensate for that un-metered air. check all vacuum hoses. and check also the MAF connector clean and tighten if necessary baka me error sa calculation ng mass air and ginagamit lang ng ecu ang default values to prevent die-out.
November 21st, 2007 05:12 PM #7
sa akin sagad na rin yun idling adjustment. 1k pinaka mababang rpm. sinubukan ko na rin reset yun ECU. nalinis na yun throttle valve.
- Apr 2007
- 42
December 2nd, 2007 04:33 PM #8up ko lang po...
servo raw po ang problema. may naputol raw po sa loob.
sabi mekaniko around 8k raw new nito???
so sa ngayon tiis na lang muna hanggang makaipon.
saan po kaya sa banawe pwede makuha nito???
hindi ko kasi kabisado lugar na yon e.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 2nd, 2007 09:12 PM #9ikot ikot ka dun if you want surplus. kelangan talaga maghanap ka sa iba ibang tindahan.
- Apr 2007
- 20
December 3rd, 2007 02:34 AM #10
Kung di mo afford ang Ferrari Purosangue , dito kana sa Xiaomi YU7:grin: - - - - - - -...
Xiaomi E-Car
