Results 1 to 8 of 8
- Aug 2005
- 8
December 13th, 2007 11:20 AM #11) honda ek96 ang ride ko mga bro's. napansin ko lang since last week na nag pa-fluctuate ung rpm ko from 1 to almost zero kapag nakatigil ako, minsan namatayan pa ako.. pero once na matagal na tumatako ung car eh wala naman.. ano kayang problema?
2) possible kaya na apektado rin ung aircon ko? kasi minsan on and off ung lamig nya hindi na consistent, nag aamoy humid tapos after 10 to 20 mins saka lang lalamig... kakatapos ko pa lang mag pa cleaning ng aircon pero ganun pa rin ang problem. nagpalit na din ako ng relay nya baka kasi ung switch ang problema.
Need your help and suggestions guys! maraming salamt in advance!
December 16th, 2007 11:38 AM #2
hey bro, you might wanna check out your IACV (Idle Air Control Valve..) also, the TPS (Throttle Position Sensor..) can cause an eratic Idle.
and about your A/C.. make sure na puno ang A/C condenser ng refrigerant. since malamang konti lang ang na ilagay nila sa A/C mo. so you might wanna have that inspected.
aite, peace.
- Nov 2006
- 122
December 17th, 2007 03:13 PM #3Makikisingit na rin po regarding rpm.Sakin naman is nababa sya from 1000 to 800 when i turn on ung headlyt pero di naman namamatay ung engine.So sa araw steady lang sya sa 1000rpm which i think medyo mataas from normal dba.Before di naman ganito auto ko(ae101) ano po kaya dapat ko ipacheck.thanks and good day to all.
December 17th, 2007 03:45 PM #4
about sa engine RPM going down when the headlight is on. well I would suggest having your Alternator checked. tingin ko "ok" pa siya for now (since hindi ka panaman namamatayan ng kotse!) pero I'm pretty sure na nag we-wear out na ang Alternator... or kundi may mahinang Ground sa Charging system. check the Battery too since it might be charging low.
also, idling at 1000 rpms is kinda "alright". pero mas maganda pa din pag nasa 900-800 rpms ang idle speed. well, what you can do is check the Throttle Body if its sticking (check mo sa loob.. it might be sticking due to gum & dirt), then check the Throttle Cable and the Idle speed adjustment screw (kung meron).
aite, peace.
- Nov 2006
- 122
December 17th, 2007 09:59 PM #6
sa akin ganun din pero nacheck na lahat ganun pa din.
pwede kaya sa computer box na problem?
December 17th, 2007 11:17 PM #7
1. ganito din naging problema ko dati sa ek ko. throttle body cleaning lang ang ginawa ok na. kung marunong ka maglinis nito i DIY na lang.
2. na experience ko itong 1&2 ang problema pala yung condenser fan nagloloko na, pag high speed ako ok , lumalamig ang aircon pag traffic yan na ang problema erratic din ang rpm. nung pinalitan ko ng condenser fan ayos na. surplus lang kasi sa casa 7k.. pootek
Tsikot Member Rank 5
- Nov 2003
- 3,848
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
