Results 1 to 19 of 19
    May 2010
    Hi Guys, really need your help. Nagkakaleak during malakas na ulan ung roof ko and i don't know saan nangagaling. Dati wala naman to bigla lang nagkaron. It's so annoying.
    I've checked sa windshield, sa antenna pero hindi dun ang source.
    Can anybody recommend where I can have this checked and fixed? Thanks in advance
    Akala ko roof ng bahay, sasakyan pala.
    Where exactly siya nagleleak?
    What car?
    May 2010
    Ford Focus and ngle leak siya sa map lights lang. binuksan ko na, hinanap pero wala padin di ko ma trace.
    Jul 2006
    Quote Originally Posted by SiRbossR View Post
    Taking a stab at it.
    Your sunroof drains may be clogged.
    See here: Water leak ?? How to test and unclog sunroof drains W/PICS - MBWorld.org Forums
    May 2010
    My focus doesn't have a sunroof. It's the TDCi model. Wala naman ibang butas or anything mounted on the roof for water to pass.
    wala rin ba antenna? sa mini cooper sa antenna yung problem e.
    May 2010
    Hindi sa antenna eh pero culprit ko talaga is antenna. Habang umuulan one time, tinanggal ko yung map light and wala naman tulo from the antenna base.
    Jul 2006
    Hot damn!
    Now that IS a problem.
    If there's nothing mounted (or drilled) on the roof, your likely culprit may be the windshield weather stripping. Water may slowly dribble in from there and creep to the lowest possible area. Remember that all it takes is a small hole (or crack) for water to come thru.
    Try hosing (gentle flow) down your windshield area and see what happens.
    May 2010
    Hot damn!
    I do think that it's the windshield that is causing it. Months before, i did not have this problem, but the car is most of the time parked in an open parking. Before, it only happened once and kahit anong lakas ng ulan, walag leak, now, nagkakaleak everytime malakas ang ulan or matagal ang ulan.
    I'll probably have to bring it to Aguila glass to have it resealed siguro.
    Feb 2009
    If you have visited shops that jack the car up from one corner instead of front or rear center , chances are that the butyl tape used to install and seal the windshield against the body has delaminated or peeled off causing a gap and leak
    Posted through phlpost.gov.ph
    May 2010
    Hmm, i'm pretty sure i havent but nonetheless, i'll have it checked and ill try to hose it with water too.
    if your car is one of those with thick butyl adhesive between the windshield glass and the metal frame...
    if you can remove the borloloy weatherstrip, you might be able to visualize the area where the thick butyl adhesive has separated from the glass/metal.
    May 2010
    Hmm. I don't wanna DIY on this cause I might Fvck it up. haha. I'll bring it to a specialist instead. I'm glad that this "normally" happens. I just hate it everytime it leaks! well everybody hate leaks.
    Thanks guys!
    Jan 2014
    Check for rust in the uuper part of the windshield where it is installed
Roof Leak
