Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Need ko po ba ng lifter? ksi ung EK ko hindi pantay ung ride, yung front and rear driver side mas mababa, pina wheel balance ko na 0.0 naman, nag palit na ko ng b-new shock and arms. sabi skin sa body daw, not sure if its true. i would gladly appreciate your help guys. TIA!
    Dec 2007
    Quote Originally Posted by veilde_slick View Post
    hey bro, what kind of lowering springs are you using?? or cut (putol) ba ang springs??
    aite, peace.
    Quote Originally Posted by KBR View Post
    aite, peace.
    stock ride lang po, walang putol. nagtataka nga ko eh.
    Aug 2007
    Its the springs.
    Dec 2007
    huh?? man, wierd yun ha! well, malamang nag sag ang springs pero bihira lang mangyari yun, specially on stock springs!
    anywayz, baka naman maraming karga sa driver side ng kotse (is the trunk full??). at kung hindi, theres definitely somethin wrong on your suspension.
    and also, talaga bang halata ang difference?? and pls. post some pictures if thats possible.
    aite, peace.
    Aug 2004
    if you want to use lifter try mo bro sa cruven shops.
    aite, peace.
    khit naka park kita sha, passenger side is lamang ng 2 1/2 fingers eh. backview parang naka lean sa driver side. wala naman po karga. ill try to post some pics later. Thanks for your replies...
    Quote Originally Posted by mcbry View Post
    Sir, natry nyo na po ba ung cruven sa may pque? ok ba sila gumawa dun?
    Aug 2004
    haven't try the cruven at sucat, bro pero yung officemate ko at kaibigan ko nagpapagawa dyan. maganda naman experience nila. dyan din kasi nagpalagay ng lifter yung friend ko for his altis.
    if ever mag palagay po ako ng lifters? anu po ba ang pros at cons ng merong lifters?
    i also think its the springs. baka malambot na. pero as posted here, napaka rare nun, specially on stock springs.
    lifters? medyo magiging rough yung ride mo.
    Nov 2006
    tanong lang ha. wag ka magagalit.
    how much do you weigh ba? pero kahit naka park na at walang tao ganun pa rin, di ba?
    baka nag sag na yung springs.
    ok sa cruven. haven't tried their sucat branch (sa Kamagong ako) but i guess same good
    service din yan. patingin mo sa kanila kasi knowledgeable sila jan.
    ganito din ang napansin ko sa ek ko mababa ng 1-2 fingers sa drivers side, parang may thread na dito dati ha. anyways nung nagpunta ako sa cruven last year for front suspension repairs, pina swap ko yung spring sa harap. L>R akala ko magiiba ng tindig, ganun pa rin . hinde ko na pinag aksayahan ng panahon kasi wala naman problema sa ride etc. feedbackan mo kami kung ok ang lifter. thanks
    Quote Originally Posted by simplicity View Post
    nyahaha, 185 lbs for a 5'8. yup i know overweight. lasinggero kse. nweiz brought it to hongly, sabi try ko na palitan springs, kaya lang iniisip ko kung palitan ko, baka mag lean pa din. so i'll try both, buy spring then lifters, pagawa ko next week because of the holiday. update ko kyo sa results.wala naman po sigurong kaso kung bilhin ko spring ng SIR?
    Dec 2007
    maganda diyan salpakan ng Coil-Over kit! hehehe. kahit Skunk 2 or Ground Control!
    aite, peace.
    Nov 2006
    medyo iba ata ang springs ng SiR sa likod. parang me nabasa ako na ganito ang sabi
    dati. paki-correct nalang po mga master.
    kasi pag naglagay ka ng lifter sa driver's side lang, baka hindi maganda ang ride/handling mo.
    kaya mag coilovers ka na lang. kung kaya ng budget. it rin ang next target ko eh.
    i encounter that same problem ... nagpalit ka siguro ng susupension arm sa likod ... kasi may left and right yan ... baka parehas na side yung nabigay sa iyo yung iba ndi alam i also just learn that myself ... if you like drop by ka sa shop ko and we can check it ... wala bayad yung check .....if that is the problem we can replace it ...
    for a short silution ... maglagay ka ng lifter sa coil spring mo ... papantay ... that was the first thing we did ... and later found out na suspension arm pala ang problem hope this help
    BANAWE AUTO SUPPLY
    7120115
    regy
    Nov 2003
    on eg and ek hondas you will never get the exact height on all 4 corners. may difference normally of a finger from left to right kahit stock or lowered ka.
    Jul 2006
    See if your subframe mounts are good, if the car has a subframe. I would advise against lifters on the coil springs, that will change the handling characteristics and possibly add to increased tire wear due to a change in the suspension geometry.
    Apr 2006
    have the same problem. yung front driver side mas mababa ng around 1-2 fingers. i know kasi when i clean the car, napapasok ko easily kamay ko sa front passenger side na wheel well pero sa driver side, medyo hirap. ride is also on stock springs/suspension. wala naman problema when driving.
    sabi sa akin kasi siempre daw laging may nakasakay sa front driver side as compared sa tapat ng ibang wheels/springs. so eventually, bumababa siya.
Ride height problem.
