Results 1 to 3 of 3
- Mar 2010
- 30
April 10th, 2010 11:00 AM #1have a 97 hilander thats not been started for 2 years. BAlak kong ayusin uli at iregister. any suggestion will be helpful, san kaya dapat umpisahan? thanks.
- Mar 2010
- 30
April 10th, 2010 06:04 PM #2the mechanic suggest that all oil be change, engine oil ,transmission oil,gear oil,brake fluid,steering oil, at the same time change the repair kit for clutch, brake,etc, also change fuel,oil, fuel pump filter. n check the battery if ok pa, then drain the remaining fuel pa.bago start . is that all, dami, pagkatapos baka may lumabas pang sira, i'm beginning to doubt to revive, kaya lang sayang nakatambak lang...
- Mar 2010
- 30
April 10th, 2010 06:05 PM #3the mechanic suggest that all oil be change, engine oil ,transmission oil,gear oil,brake fluid,steering oil, at the same time change the repair kit for clutch, brake,etc, also change fuel,oil, fuel pump filter. n check the battery if ok pa, then drain the remaining fuel pa.bago start . is that all, dami, pagkatapos baka may lumabas pang sira, i'm beginning to doubt to revive, kaya lang sayang nakatambak lang...
[QUOTE=ice15;3387274]medyo disappointing itong Sealion 5 No front sensor either Manual Seats...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
