Results 1 to 10 of 26
November 1st, 2004 08:19 AM #1
I read once in a post about resetting the computer of a '03 Lancer MX. but I can't seem to find in the manual where it is most likely hidden (most likely they wouldn't put in the manual anyway). Can anyone help me on this?
November 1st, 2004 11:10 AM #2
diba pag tinanggal ang battery for more than 15 mins na rerest siya?cmiiw.
November 1st, 2004 11:36 AM #3
others say na remove the battery terminal and step on the brakes pra ma ubos daw ang electricity for ten seconds.
November 1st, 2004 11:54 AM #4
oo nga ma rereset yung mga previous input, pati tranny pag invects 2/3..not sure kung gano katagal, ako over nigth para sure..
November 1st, 2004 01:53 PM #5
Anywhere between 30 secs to 30 minutes... make sure the key isn't in the ignition. 5 minutes should be long enough.
November 1st, 2004 02:20 PM #6
just disconnect the battery positive terminal for a few minutes. wala naman back-up battery yung computer. ako i always make it a point to disconnect the battery before a long drive to erase the computer memory (in particular the driving style settings). naka-memory na kasi yung driving style na city driving, di pwede yun sa highway na kelangan mag-overtake ng mabilis.
Tsikot Member Rank 3
- Jul 2004
- 1,540
November 1st, 2004 05:25 PM #8
yup. kasi pag city driving mabagaal lang arankada di ba, so the computer (of the tranny) memorizes this style of driving and thus it shifts early. sometimes even if you floor the gas it will hesitate before it downshifts. pero after disconnecting the battery the memory is erased and the computer starts from scratch again, no "city driving habits" in its shift pattern. mas maganda arangkada as it stays longer in gear, downshifts readily when you need to overtake, etc.
pero of course this assumes that your highway driving is different from your city driving. if you drive the same way then bale wala.
November 2nd, 2004 06:04 PM #10
hehehe, kala ko din PC...
i agree with yebo's practice of resetting the ECU before and after long drives
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
