Results 1 to 10 of 11
- Dec 2005
- 244
October 11th, 2007 10:01 AM #1Need help guys! Nanginginig ang lancer ko during high speeds from 80 to 100kph. Di naman sya hard starting from cold start usually one click lang sya sa umaga start na. I noticed this problem nung mag pa tune up ako. I had been using iridium spark plugs before my recent tune-up and sabi sa kin nung mechanic dapat daw yung may resistor gamit ko. So pinalitan nung nag patune-up ako and just recently nanginginig na sya at high speeds. Could it be spark plugs or may diperensya na HT wires ako. i will have it serviced tomorrow and i wan't to know from you guys where to start. Thanks.
Details of the car:
Mits Lancer MX 2000, INVECS II tranny.
October 11th, 2007 10:07 AM #2
Um... how do you define "nanginginig"?
Does the engine strain to accelerate? Or does the steering wooble?
October 11th, 2007 10:13 AM #4
October 11th, 2007 10:22 AM #5
Possible na nawala ang lead sa mags mo, baka kailangan na ipa-wheel balance mo ulit.
- Dec 2005
- 244
October 11th, 2007 10:39 AM #6the steering doesn't wooble. the whole car is vibrating and it seems to come from the engine. The rpm when idle is around 800-850. I asked my officemate to come with me awhile ago and he says there's something wrong with the "timing"?. I just noticed awhile ago that there's also slight vibration when it reaches it's normal idling of 800-850.
I forgot to mention that during my last tune up the mechanic did some adjustments on the clearances of the "valves" (i'm not sure if it's those valves) may ginamit syang parang mga maninipis na lata to measure the clearances.Last edited by Imau; October 11th, 2007 at 10:45 AM.
October 11th, 2007 10:51 AM #7
could be the timing, but since you are going back to the shop for re-timing, i would suggest that you revert it back again to stock plugs.
i've heard din kasi of guys who are using iridium plugs tapos nagkakaroon ng misfiring/vibration when they used these. when they reverted back to the stock plugs, medyo umayos ang takbo ng engine nila.
hindi sa HT wire yan dahil, pag HT wire, may loss of power and you cannot really accelerate to more than 40 kph.
October 11th, 2007 10:54 AM #8
I don't think that this has something to do with your engine.
Try revving your engine until the redline while idling... if the engine hesitates on of your plugs might be misfiring or something.
Though it could also be a case of a busted engine support or shock stop (or even a misaligned wheel).
- Dec 2005
- 244
October 11th, 2007 10:56 AM #9
- Dec 2005
- 244
October 11th, 2007 11:00 AM #10
high idle RPM at engine start
