Results 1 to 7 of 7
September 13th, 2007 01:39 PM #1
Hi guy,
For the mod: Nag post ako kanina, hindi ko na makita, if repost ... please delete...
Anyway, here is my problem, my 1999 honda city a/t (type z) is having intermittent problem when starting the car... Ayaw mag crank.. bago na battery.. I had a mechanic check the starter - malakas pa daw ang solenoid.. any tips how to solve the problem?
- Dec 2006
- 273
September 14th, 2007 01:15 AM #2imperialv,
ganun din sa akin, ayaw mag-crank. a/t din kasi car ko. palagay ko, may nabasang sensor sa a/t, pa-check mo lahat ng connections, baka nabasa or maluwag lang.
Tsikot Member Rank 4
- 2,719
September 14th, 2007 01:57 AM #3i you hear a click (of the solenoid) but won't crank the starter motor, the solenoid is actually not receiving enough current to operate properly (it moves the plunger but does not close the motor switch) ... it can be tedious to troubleshoot this problem as there are several points where voltage drop could occur ... a quick solution is to install a relay to eliminate voltage drop ... an auto electrician will know what to do
this i did on similar car as yours
September 14th, 2007 02:02 AM #4
In some cases it can be the sensor that detects when the vehicle is in PARK or NEUTRAL that is defective (inhibitor switch ba tawag dito?).
But if you can hear the solenoid, it means the switch is working is electricity is flowing to the starter...
September 14th, 2007 06:39 AM #5
thanks guys... nag crank yung starter.. ayaw lang mag click... i'll try to have a relay installed...
thanks.
September 14th, 2007 02:05 PM #6
Tsikot Member Rank 5
- Nov 2003
- 3,848
Thread was made nung 2018 pa po sir.
